well this is my kinda blog, to my swap.... so i bought a l3250 2wd it came with a front end loader, guy told me engine was toasted so i pulled it apart an crank was toasted..... so i started a looking for an engine v2203di.... called every where under the sun...
an i found a whole tractor for cheap gst l4200 v2203di 4x4 ... guy said the thow out bering is stuck also 3 pt lift is not working but engine runs good.... so loaded it up hard to drive with not clutch.. got home drained the fuild it was brown fuild..... i know l4200 got alot of gst problems.... but engine runs good also it has good 4x4 on the front of it....
what would yall do pull the engine out of the l4200 swap it to l3250
or would yall fix the l4200 4x4 an put the front end loader on it.....
