3710 mid PTO quit
Hartless
10
Marquette
I was out snow blowing and the snowblower quit. Rear pto is turning and the mid PTO is not. The lever that is moved down to engage the mid PTO had moved like it was being taken out of gear while I was snowblowing. I have attempted to re-engage the mid PTO with the lever but it is not working. Have sprayed all moving parts of the lever with wd40 and the lever appears to be moving everything. I can turn the auger by hand and it turns everything back to and including the mid PTO. I did not hear any noise when it quit like gears grinding or breaking. Currently searching for similar results. Any suggestions are appreciated. Thank....Rick
Hartless
10
Marquette
Fixed. Hand wife work the lever and I turned the PTO by hand and it clicked into gear. Someone hand suggested that on a different thread.
5,069
You need to give more information...
For starters.. it's not just a 3710...
It's a lot more than that, like:
L3710 DT
L3710 GST
L3710 HST
