Well...while I’m admitting my own mistakes...
3,032
I bought a FM-180 Finish Mower from Betsco and am generally happy with it.... but I ran over an unseen object and it made a minor bend in the center blade, so I decided to remove the blade and straighten it in my shop hyd press.
Being above “avridge-intelli-gents” and “e-kwipped with hevy-dootie tools” I decided to use my impact wrench to remove the blade. It was a 21 mm head on the bolt so I grabbed my 21mm socket and pulled the trigger on my impact ... and promptly ripped the head off that bolt! :eek:
The owner’s manual didn’ menchun enny-thang ‘bout a LEFT-HAND bolt on that spindle! :eek:
Called Betsco and those bolts are one-month back-order.
Went to Fastenal...and they refused to allow anyone past the front door because of the virus.... so told me to come around to the BACK door! :rolleyes:
They measured it to be a M14 X 2.0 X 30mm bolt, 8.8 hardness. They’d be very happy to order some for me... $7 each.... minimum order, a bag of 100!
Figured it’d be awhile before I can mow again.
Then, Amazon shows M14-2.0-50mm LEFT HAND bolts, Two for $15, two-day Prime delivery. Arrived today....Sunday!
Cut it to length, installed and mowed 3 acres in an hour.
Very Happy. :p
Wishing there was a bolt-head identifier for LEFT-Hand threads.
dlsmith
BX2230, LA211
Nov 15, 2018
1,195
706
Goshen, IN
That must be one powerful impact to instantly twist the head of a 14mm 8.8 bolt.
3,032
Actually it’s a fairly inexpensive Ingersoll-Rand running at 90 psi.
I was surprised myself.
Pau7220
Aug 1, 2017
785
276
Scranton, PA
I use McMaster Carr for darn near everything.... they don't even have them.:confused:
fruitcakesa
M 6040
Oct 26, 2010
852
265
Cavendish Vermont
Say what you will about big tech and big business, Amazon, is for many of us, the source of last [or first] resort:)
3,032
It’s such a wonder, that Amazon took Sears & Roebuck’s original idea.... and buried them with it.
Either Evolve.... or cease to exist...
KHW59
L-3901 Brushhog, Finish mower, road planner, box blade.
Apr 28, 2016
60
Palatka Fl
Been there did that:(
My tool of destruction was an electric HD Milwaukie 1/2" drive impact.
B737
LX3310
Jun 9, 2019
2,024
2,194
New Jersey
just about to change my mower deck blades for the first time, thank you for this humble PSA!!!
3,032
What makes so little sense about this is, viewed from the bolt head.... those blades turn counterclockwise. Resistance from grass, etc would tend to LOOSEN those bolts!
Maybe it’s because China is on the other side of the date-line...:confused:
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
1,771
861
Near Lancaster, PA, USA
I could be wrong, but many years ago I had a 59 Buick. I seem to recall that one side of the car had RH lugs and the other side had LH. This might be the same car that had lug bolts instead of lug nuts. One of my early cars was like that and they were a real pain.
dlsmith
BX2230, LA211
Nov 15, 2018
1,195
706
Goshen, IN
Yep, my first car was a '59 Buick, and I figured out pretty fast that one side had bassackwards nuts on the wheels. I put Keystone mag wheels on it and had to change all the studs on the left side to right hand thread so the lug nuts would work.
I think some Chrysler products were that way also, in addition to most big trucks with Budd wheels. What a PITA.
