First off, thanks for the help I've gotten from this site so far! It's been a good resource to help get my Kubota back in action. Second, I don't know where to put this so I'm just throwing it here since this is a little beyond "service and maintenance".
A few months ago I picked up a used TG1860G for $500. It came with a TG2746A snowblower, TG2754 dozer blade, and RCK54TG deck. I knew it needed work before buying. The transmission was shot and although it moved under its own power, it jerked really bad and sometimes slipped. I said no problem, I'll rebuild it and have myself a nice machine for both summer and winter that can replace the craftsman mower and walk behind snowblower setup I had been using.
For starters, the transmission was toast. Gears broken, bushings snapped, metal everywhere. I did a full rebuild using about half new parts, totaling another $500. So $1000 isn't a bad deal for everything I got. Transmission was fixed, mower deck was cleaned up, sharpened the blades, couple new small pieces and I was able to mow my lawn.
Here is a video showing the assembly of the transmission. I was surprised how simply it was. https://www.youtube.com/watch?v=wlIFsQR7S2s
Now mowing season is done, it was time to service the snowblower. A couple pictures from the day I got it. A bit rusty, really dirty, and had to evict some hornets.
After getting it into the garage to service it I noticed quite a lot wrong with it. The rust was way worse than I originally thought, the impeller was dented to the point of probably not working, and the gearbox seals were leaking (it had almost no oil and lots of water inside).
