I finally got the FEL spill guard finished and installed today. I had a local shop cut the pieces of steel for it, I welded it up and took it back to them for blasting and powder coating. The powder coating came out great as you can see in the pictures.
I added two features to it that seemed to make sense to me. One is an opening in the middle with expanded metal welded in to let you see some of what the guard blocks.
The other feature was a pair of small doors on each side in front of the hooks I have bolted to each side of the bucket. The have little tabs that lock them shut when not in use and have stainless steel spring loaded hinges. That way, I can use the hooks just as I did before I put the guard on.
All told, with the steel and powder coating, I have about $200 in it.
