L1802 3 point slow when raising
mrwolfe
L1802DT, slasher, carryall, hayes posthole digger, kanga blade
Sep 16, 2019
25
Lilydale, Vic, Australia
I have the ZL1802. Mine has a valve right in front of the seat that controls the speed of the lift. I have to open it a little during cold weather.
I believe hat knob controls the descent speed of the 3PH. Mine is frozen in the maximum position (probably have to get that serviced). Strange thing is that he 3 point is not too bad when cold, but stops working when it heats up.
mrwolfe
Sep 16, 2019
25
OK, more on the 3 point saga.
Replaced the pump. It's not that.
I'm still trying to figure the filter thing out. Today I went down to my local Kubota dealer and asked for a 38430-37710 filter. He doesn't have any in stock. Apparently they are no longer avaiable, having been replaced with 30400-37710. I already have a new 30400-37710 filter on the tractor, and it has a paper element. He suggested that the oil could be too thick, said he'd seen that a lot.
Next thing to figure out is what grade of oil is correct for the L1802. I have Agritrans 10W-30 UTTO GL4 in it at the moment, which is what was in it when I got the tractor. It looks like the correct grade is 10W-20. I replaced the oil with the same stuff, so maybe that was the problem.
Actually, looking more closely at the filter, it's NOT paper, but brass mesh. There was some foamy oil on he inner surface that made it look like paper.
mrwolfe
Sep 16, 2019
25
So, I finally bit the bullet and took the thing down to my local AgPower dealer to have it looked at. I initially went to the Kubota dealer a couple of doors down, but they wouldn't even give me the time of day. Nope, grey market import, go somewhere else.
IF Kubota think that I will EVER buy a new (or even used) machine from them in the future, they are VERY much mistaken. In my view it is unconscionable to turn your back on customers and refuse to help them AT ALL just because you had a tiff with some ex-partner 30 years ago. SHAME, KUBOTA, SHAME!
Anyway, it turns out that the pump I put in was stuffed. Apparently, the hydraulics on the L1802 (and probably the rest of the L series as well) are a beast to get primed and bled properly. The pump had run dry and chopped out. AgPower were't able to get a replacement (Kubota were no help at all as usual, AgPower asked me if I had a part number that I could give them), it appears that there are none of this $1400 item in country (seriously, $1400?). I took the old pump down to them, and upon inspection it was found to be in much better shape than the new one so they installed it.
After draining and flushing the transmission case, bleeding the hydraulics and adjusting limit stops and pressures, it's better than it was when I got it. Turns out that, apart from a knackered pump, the oil had water in it. The main culprit was the vented filler cap in the top of the transmission housing (The big one between the drivers feet).
The cap is supposed to have a rib along the centre to unscrew it with, but it's broken off on the one I have. What remained was a rectangular trough that turned out to be very efficient at catching rainwater and dumping it into the transmission case. I filed the ends of the trough flat, glued some paper over the base of the trough to seal it (leaving the air channel clear) and filled the trough with epoxy.
