Canadian Supplier of tire chains.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,124
931
Williamstown Ontario Canada
I know this is late info.
Walco supplies most tractor dealers with tire chains.
http://www.walcoequipment.com/product-catalogue/tire-chains/ontario/walco-tire_chain
Critical info is tire diameter. Not all tires are made to the Tire and Rim Association standards but the tire chain people follow those dimensions.
This page from the TRA handbook is likely for tires much bigger than yours but will give you an idea.
You cannot assume that buying chains based upon the tire size on your tire sidewall will get you chains that fit!
Dave
Tommieboy
51
Ontario
After shopping around and trying to find something used I finally went with the Twinway 6 studded chain from Walco. I had to order through Kubota as they don't deal with the general public. Not cheap at $720 before tax but it's the chain I need to get up a steep gravel incline in the winter and through the woods in the spring.
I also switched the rear tires around and dished out the rims to give me a wider stance, I found it does make a difference and gives a more planted feel.
BigG
Sep 14, 2018
1,950
774
West Central,FL
I am just wondering, it looks like the tires are aired up. Would it help to soften up the tires?
Tommieboy
51
Ontario
The tires are loaded, I took possession of the tractor from the dealer last spring and haven't checked or changed the air pressure. I'm assuming the tire pressure is where it should be but I'll check it.
3,821
Don't forget to rotate the tire valve to 12 o'clock, so you don't have the valve stem spitting at you. :D
Hodgy
B7800, front blade, box blade, subsoiler & 3 PTH snowblower
Apr 19, 2019
126
9
Finally got the used tire chains cut down and installed on the B7800. Went out today and trimmed some of the banks on the sides of our road. The county has not sent out the grader to wing out the snow and only uses the truck with the one way speed plow.
I used the blower today to open up a driveway for one of the "cabin people" we have out here. So far this year we have had 68" of snow. The B7800 chugged right through blowing as it went. The chains really make a difference.
Here is a youtube video showing the chains installed on the tractor.
https://www.youtube.com/watch?v=ZYPQM2qIq4w
vic gerbasi
M110 L3300
Feb 19, 2016
232
dugald mb canada
ok I got them measured--- 14" wide 6' long i dont know what size wheel and tire they will fit im asking $75 and you pay the shipping- by truck i presume they are heavy buggers
vic gerbasi
M110 L3300
Feb 19, 2016
232
dugald mb canada
I have a set never used dont know what size wheel and tire they fit 14" wide by 6' plus a bit long i will never use them so maybe you can $100 and you pay the shipping - by truck i think they are HEAVY you could text me 204 771-5357 Im very near Winnipeg
have a great day
