Turf tires for an l1501/ l185
4,488
I got three really good suggestions for doing the center hole. NIWolfman suggested rigging up something to hold a torch or plasma cutter and spin the rim.
I ended up using a combination of the three suggestions. I dug around the shop at work and found a pipe flange that had the correct inside diameter I needed.
Used tooljunkie's suggestion of bolting it to the rim. In this case I used some threaded rod and fender washers. Checked my measurements about 30 times to make sure it was centered.
Then used wolfmans suggestion and used the flange as a guide and torched around the inside. It cut my grinding down to a 1/8" :D
When the rims finish cooling I'm gonna mark the edges of the hole again and use d2cat's suggestion of a carbide burr bit to finish it. But in this case run the burr bit in a Dremel so I can finish it at the house and check fit on the tractor as I go :D well the dremel won't work. But there's always plan "B" which is using the carbide bit in a corded drill :)
4,488
These are a lot of work!!! :D three hours on one rim. Got it to fit the hub and two of the holes have been extended.
Four more holes to go and I'll have one rim fabbed up :D
I would kill for a plasma cutter right now!!!!! :rolleyes:
4,361
Daren, if you're going to leave the ugly side out you have to at least paint it when you're done!
And a few hours isn't bad for all you saved on used Kubota wheels, plus shipping.
4,488
I don't have much of a choice but to leave the ugly side out. :eek: They won't fit the other way :rolleyes: Already got the paint and primer :D was left over from when I painted the box scraper. Gonna have to do a little welding on it to fill some grooves and grind them flat to give a good solid, flat surface where it meets the hub :D This way I avoid the dreaded wabbles. That I will do at the shop. We have a good miller 252, so I will be able to dial it in where I need it. And less time and clean up between passes :D
4,488
Broke my bit saturday :eek: just got a chance to get by napa to get a couple more carbide bits. Got the first rim finished as far as fit goes. Got two holes on the second rim done. Made sure the rim was good and centered. Now working on the center hole which is slow going. Got it real close then started getting tired and impatient :rolleyes: so I stopped for tonight and will get back at it tomorrow night. My goal it to have both rims fitted by thursday. And then fill in the grooves on the side that mates to the hub on friday. Then hopefully have the tires on the tractor for a test with the mower saturday :D We've had so much rain that the lawn turned into hay field again :rolleyes:
2,154
Daren,
been following the work ! - looking good! - slow and steady, I too rush too fast sometimes to get the second one done. Cant wait to see the finished product!
4,361
Daren, I had to modify some wheels for a trailer many moons ago. I needed to make the center hole smaller so it would ride on the shoulder and no on the studs.
I bought a 3' length of 1/4" key stock. I found a PVC pipe near the dia. I was needing. Wrapped the the key stock around the PVC to get close to the working diameter. Then set the key stock in the hole and tacked with wire welder. Proceeded around until I cut off the length to fit it all tight. Then welded the entire piece to the wheel.
You might try something like that if you need additional iron on the inside between the bolt holes and the center hole.
Worked excellent. Still using the trailer.
4,488
The center of the rim came out good :D if you look at the picture of the good side of the rim you'll see where the lug nut holes are, that it sticks out from the face of the rim some. That's the side that will be facing the hub. There's maybe 1/16 of material actually making contact to the hub where it bolt's to it. I need to fill in the good side some around the holes for a better mating surface
4,488
Got the second rim fitted for the hub tonight :D
Now I just need to fill in the grooves on the good Side of the rim to give it a flat surface to mount to the hub
If everything goes right and I don't have to pull another double shift I should be able to get the tires mounted Saturday :D
4,488
That was one of my concerns too. So rather then just throwing a set of tires on it and bolting it up, i'm gonna do some filling tomorrow with the wire feed :D give it a flat surface front and back.
5,062
On the outside of the rim weld on some washers, that will restructure it perfectly!
4,488
Great idea :D I'm gonna have to test fit the rims again when I get home tonight. Got the grooves filled. Slipped over in a couple of the holes a touch. Same with the center of it :rolleyes: did give it quite a bit more meat though :D
Now I have quite a bit of grinding to do!!!
4,488
I do believe it's time for an adult beverage :D
The tires are mounted onto the tractor :) now to scotchbrite the rims, wipe of the crud and paint them baby's :D after I have a beer or two :rolleyes:
Picked up a couple of Chevy work truck rims for $180.
Got a pair of used falken wildpeak mud tires. 37" tall for $100
Plus a couple cans of paint and primer.
10 hours of labor, plus 1 1/2 pounds of wire.
Total cost was $302 :D
A used set of turf rims were $500, plus around $280 per tire. Saved $700 !!!
4,488
I still got the rice paddy tires :D:D:D take me ten minutes to swap them over :D:D
Now I got a swamp out back to hay :rolleyes:
4,361
"Saved $700 !!!" It's not about the money saved it's about the character building process of making something that didn't exist before you started!
Now you'll be sniping the tires.:D Nice work, Daren.
4,488
Rims are all prettied up :D gave the tires a light coating of oil so I can wipe off the over spray in the morning :D
Tooljunkie
May 13, 2014
4,150
27
What really bites is i had a set of 37" tires a couple years ago. Sold em cheap. Now im looking for some that will work. 11r22.5 semi tires are same height.working on a plan for my buddy's cnc plasma table and wheel centres should be a breeze.
