Tire chains. Type and source?
olekid
B7510,loader, Curtis heated cab, loaded tires snowblower,grader blade,snow plow
Apr 9, 2013
92
Mount Uniacke, Nova Scotia
I use Valby Talon studded ice chains, from Northeast Implement-ice chains, they were expensive, here in Canada I paid $500 over 10 years ago. Well worth it they work great o my Kubota B7510
5,099
bearbait,
I would go with the 3/4 ones, that way a little extra pressure on a stud won't cause an issue!;)
lamanated
BX
May 2, 2013
55
Zephyrhills Fl
I just installed sheet metal screws in my industrial tires on my bx,, worked well so far, I started in the middle and worked out in a V using every second lug , I used bolt cutters on them, to make them about 5/8 long ends were touched up flat in the grinder, and they went in no problem. fronts I made a 1/2" long
bearbait
Dec 9, 2011
4,007
751
New Glasgow Canada
I didn't receive mine yet but I the picture you can see the problem I'm having where the road slants to one side.
5,099
Part of my driveway is at a 10% grade, (to be changed this next summer) with the studs in mine I can crawl up and down a now 1" thick ice sheet without a problem. You'll love it when you get it set up!
Your driveway look just like mine!;)
bearbait
Dec 9, 2011
4,007
751
New Glasgow Canada
Wolfman, do you just have them on the front or back to. I placed an order for 3/4" but they came back a few days later saying they were out of stock. They had 5/8's in stock so I settled for them...hope they work.
5,099
I just have them on the front's, I have an odd set of shallow double treaded low profile flotation tires on the rears. I have chains for them but need wheel spacers to clear the fenders. I also still need to ballast them.
They have proven to give me excellent traction on both the snow and Ice.
Rear tires
Front tires
bearbait
Dec 9, 2011
4,007
751
New Glasgow Canada
My studs came in today and they are now in the tires. Looks like i'm just in time...another storm coming mid week.
5,099
bearbait,
I hope they work as well for you as they do for me.;)
When we got nasty Ice I could get around everywhere with no problems.:D
bearbait
Dec 9, 2011
4,007
751
New Glasgow Canada
bearbait,
Thanks for the advice and help Wolf....had a chance to clear a lot of snow the last few days and the studs work great and the price was right. Thanks again.
5,099
I'm glad they worked for you too, I know mine work like a charm.
5,099
B7100 chains are easy, go get a set of diamond link chains for a truck.
33x10.5x15 will fit the tires you have.
One exception is if you have rice tires (really tall tread) no chains will work on those, or non well.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
I put #14(1/4")x5/8 slotted hex head sheet metal screws in my R1s. The hex head is a 3/8 wrench size. Traction is awesome! I used 2 screws per bar on the front, 3 per bar on the rear.
The rear tires are doing fine, but several screws have pulled out of the front tires. I don't know if it is the smaller diameter of the tire, or possibly a softer rubber. It was the center screws that pulled out. 3/4" screws might hold better.
I just ordered a hundred Grip Studs (#1800) for the front. They are about $1.15 on ebay, $1.02 at Saltwater Edge. I doubt they will pull out. Even at $1.15 they cost much less than diamond pattern chains. "They" claim you can screw them out in the spring, or just leave them in. Time will tell...
http://www.gripstuds.com/Info.php
bearbait
Dec 9, 2011
4,007
751
New Glasgow Canada
I check mine after every run and they are holding up very well...haven't lost one yet. I have noticed that the back end is breaking loose at times so I may just stud them also.
