BX and a 4' brush hog ??
Yoder409
BX1850, B2630, L2350, MX5000, M6800
Jun 9, 2019
19
Swellview
Thinking about possibly upgrading my BX1850 to a 2670 or 2680.......... IF it would handle a 4' rotary cutter. Do the 26's have the PTO grunt for it ??
I'm not concerned with the weight, so much, as I run 180 lbs (beet juice & iron) on each rear wheel of my 1850 and chains . Would do the same with a 26.
dalola
BX2380 w/FEL & Woods RM48 RFM, Yazoo/Kees Max2 ZTR
Jun 30, 2017
316
I run a 48" Woods on my 2380 with no issues, could probably take a 54", but I choose the 48" for narrow trail mowing.
You should be fine.
SDT
multiple and various
Apr 15, 2018
3,084
923
SE, IN
Should be fine so long as your mower is not a super HD model weighing too much.
SDT
B737
LX3310
Jun 9, 2019
2,024
2,194
New Jersey
I have BX2350 and run a Land Pride 42" rotary cutter, it is a beast (by residential standards). I have the shear pin version which was difficult to find, most people seem to stock slip clutches
The RCR1242 can do in 4 hours what used to take me 3 days with a walk behind Brush Hog over 2 acres.
If you keep the FEL attached the entire tractor is about 18 feet long, I remove the FEL and use 4x42 pound John deere weights and hang them off the front frame, and like yours the rear tires are also ballasted.
Cglaza
L2500DT, BX2380, G6200H
Aug 30, 2015
170
Freeland, mi
I have a land pride 48" mower on my bx 2380. No issues for power at all but you will want to run weight in the front such as your loader or add on weights to keep the front end stable.
Sent from my XT1710-02 using Tapatalk
Yoder409
Jun 9, 2019
19
Swellview
Appreciate the info,.fellers !!
Where I will be mowing is pretty darned steep. So the FEL will be off. But only because of turning at the bottom to go back up. No problems hanging some front weight.
edritchey
A bunch of cute little Kubotas
Jul 19, 2014
1,059
731
Wellsville, PA
I ran a 4' bushhog on my BX24 all the time it never had any problems with it.
ehenry
BX22, FEL, BH, 40" pto tiller, 42" Bushog Squealer, pto hole digger, B7300 w/60"
Mar 25, 2014
356
88
Canton, MS
I run a Bush Hog brand Squealer 42" on a B7300 which doesn't have the horsepower my BX22 has and it handles it just fine.
B737
LX3310
Jun 9, 2019
2,024
2,194
New Jersey
Im new to this, but couldnt the 1850 run a 4 foot brush cutter?
SDT
Apr 15, 2018
3,084
923
SE, IN
Yes, but not well.
You will be HP limited in moderate/heavy cover.
Again, you will need front weights on anything but flat ground.
SDT
Yoder409
Jun 9, 2019
19
Swellview
Weighted rear tires won't help keep the front on the ground. You will definantly need some weight on the front.
Yes. Front end weight will be a given.
The weighted rears (and chains) are just every day trim.
Jpatrick
BX1850, L210, Various 3 point implements
Apr 4, 2017
100
Buckingham, Pa
The operator's manual for the BX 1850 rates it as able to handle a 4 foot rotary cutter. I have actually used a 5 foot L&S brush cutter on my BX 1850 with good results. Since the tractor has hydro drive, you can adjust speed to fit the mowing job.
That said, don't expect to go blowing through 5 foot sedge in high gear.
Yoder409
Jun 9, 2019
19
Swellview
Most of.the usage will be between rows of Christmas trees. So there's really never any REAL heavy cutting there. Other than that...... I have some woods roads to maintain and a pretty lousy steep hillside of briar, goldenrod and timothy to keep at bay. Not more than 6-8 acres of that.
SRRGC1
BX1870-1, BX23S TLB, RTV XG850, MX5100DT
Jan 6, 2021
208
75
Bloomsburg
More than enough HP. Front weight for sure and don't raise mower when going up hill to be safe.
3,931
OK, thinking out loud here...
why not BUY the cutter now , try it out.
if your 18 is lacking power or stability THEN buy a bigger tractor ?
You need the cutter anyway......
SRRGC1
Jan 6, 2021
208
75
Bloomsburg
Probably do a 54 or even a 60 rotary mower if cutting is lighter duty with the 26. Cut you mowing time down unless you really enjoy mowing.
