coachgeo
saw below image elsewhere...... got me thinking.... you think that load binder he used to pivot the hole thing could be used similarly to pivot the blade itself while also acting as a replacement for the pin??? or would it not stand up to the torture?
As typical the hole on used and abused back blades the pin hole is hollowed out anyway and needs welded and rebored on mine. (or drilled out and sleeve welded in)
