Yesterday I mowed with the B2320 for several hours, turned off the engine for an hour or so, and when I returned to start the tractor up again nothing, no clicks or any other sound or lights on the dash when I turn the key, and no headlights/turn signals when I try the light switch. Battery is fine - I can crank the engine by shorting the starter solenoid terminals, and cranking speed sounds normal, but it won't start, I assume probably because of a stop solenoid on the fuel pump. All the fuses in the fuse box by the starter are good.
Next I was going to check the key switch which is mounted on the big plastic cowling. I have a puller for the steering wheel, but I only see one attaching screw on the center top of the cowling and don't see how it comes off. Would appreciate info from anyone who's done this!
Thanks much,
Howard
Thanks much,
Howard
