Tabs on the rims
freeon
23
What is the purpose of this part of the tab? Is this to add strength/rigidity? Someone suggested it might be to bolt a wheel weight. As you can see from the picture the tab is rusted. Some even worst than this one. Can I just put a flat plate instead of that Z shaped one? I would use the same thickness.
4,035
Assumning it's a two piece rim, my guess is that you can put the rim on the 'other' way, to adjust the track ( wheel to wheel spacing). Lots of tractors have that ability..used to get the tractor spaced right for the crop you're planting.
