Size Disc Harrow 47 hp Kubota MX 4700
BigG
Sep 14, 2018
1,949
765
West Central,FL
What size disc Harrow should I consider for the above tractor. The spec of the tractor says max 2 bottom plow 16” max. Thanks[/QUOTE
What are you using it for? Food plot? Gardening? Corn field? How big of an area?
mbu
260
United States
The Owners Manual for your tractor should give you the manufacturers recommendations under the heading Implement Limitations.
The following information may not be of any help but..
I could not find a manual download for the mx4700 but the mx4800 recommended a 72-inch width.
BigG
Sep 14, 2018
1,949
765
West Central,FL
72 inch 3 point disc will cover your tracks. For a food plot I would look at the weight of the disc and get the heaviest that the tractor can lift. If you can not find a heavy weight make sure you can add some weight to improve the chopping ability of the disc. Add a log or a piece of an I-beam in order to get it to cut.
SDT
multiple and various
Apr 15, 2018
3,084
925
SE, IN
A 6' should be OK if it is not too heavy.
SDT
Creature Meadow
Sep 19, 2016
1,063
135
Central North Carolina
Another option for improved cut is to get one you can adjust the pitch.
It was free so I pull a 5' disk with my 46hp tractor, it does not know it is there but again it was free so I use it.
When cutting my plots for the first time each year I pitch the front to the max and tilt disk down in the front so rear is barely rolling dirt back in.
Disk once then in opposing direction. Set disk back to nearly level and straighten pitch back for smoothing and leveling.
This works great for me in my 3 acres of plots and 1 acre garden.
As far as a plow you can adjust the height you drop it until you get the dirt worked.
I only use plows when I want to turn in a lot of material such as grass, leaves, or if it was a fallow area. Otherwise turning up dirt from deep in my area lacks nutrients, most of which in my soil types is in top maybe 6 to 12 inches of soil.
