Zirks all the same ??
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
315
26
23
Mobile, AL
I’ve got a L3800 and I need to replace a few clogged zirks. Does anyone know if the zirks on my tractor are all the same size and same thread type? I’ve never replaced one before and I’d like to buy a kit to keep on hand. Thanks.
3,102
I doubt that they are all the same and have run into issues in the past. Although, It seems many are M6 sized.
Check out the harbor freight storehouse assortments. I recently picked up both the SAE and Metric assortment boxes. They are a great deal. I now have fittings for just about everything.
JG4660
47
Buffalo
Seems they are not the same on the tractor vs the loader, backhoe, etc...i just replaced one today and i went to Kubota.com/parts and looked up my loader and it listed the zirks. For mine it was a 1/4-28 tapered. About the only way i know unless you have a large asst of fittings.
JG
Mister
130
Northwest
Harbor Freight is good for some things, and absolute garbage for other stuff. What's the consensus on their zerks?
Sent from my SM-N960U using Tapatalk
SidecarFlip
Banned
546
Actually the proper name isn't Zerk, it's an Alemite fitting. and the HF assortment is as good as any. and cheaper than most. When mine get wonky, I replace them.
You can buy one of those nifty unclogging tools at Gemplers that you fill with oil and put it on the fitting and wack it with a hammer and that clears the fitting for 40 bucks or so but I use synthetic teflon fortified grease so my fittings don't clog up and you can buy a bucket full of fittings for 40 bucks.
Just my opinion as usual.
2,947
Actually the "proper" name is "grease fitting" and it was designed by a guy whose last name was "Zerk" so calling it a Zerk fitting is primarily correct. The first company to mass produce it under Mr. Zerk's patent was the Alemite company, so "Alemite" fitting is the secondary identification of check-ball type grease fittings. Alemite is no longer the primary mfr'r of them so the more universal term "Zerk" is in wider use. ;)
"Wonky" is British/Aussie/New Zealand slang for "misaligned" "crooked" or "awry" none of which mean "clogged" therefore improper adjectives for inoperable Zerks, even in American English, but maybe explains some things lately. (Where IS that tongue-in-cheek emoticon anyway...???) :confused:
Zerks which are "stuck" or "clogged" can be cleared with that tool you mention, but it's bad form because it forces the dirt-clog down into the bearing and damages it. That tool should only be used with the Zerk removed from the implement for clearing, then may be reinstalled.
But it may be simpler to throw it in the trash and install a new Zerk instead.
Zerks are made with SAE or Metric threads usually, both straight and taper or "pipe" and should be replaced with the same, so an assortment of Zerks might be the answer for the home handyman. (There rarely exist some un-threaded types which are press-fit but none in common useage.)
Horrible Fright Zerks are as good as any I've ever used and solve the problem nicely.
To keep them from clogging, one might consider what is common in aviation use... Zerk Caps, which protect them from dirt and water ingress.
https://www.amazon.com/gp/product/B07FXPK7SF/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Mister
130
Northwest
Lol. Right, because everyone runs around referring to them as "Alemite fitting". "the proper name isn't tractor, it's internal combustion engine farm utility implement".
Give me a break
SidecarFlip
Banned
546
Give me a break
I did. Give you a break, I didn't break it off in your posterior.
I wasn't snarky at all. Just stated the proper name. I could have been snarky and stated that the OP misspelled the street name too.
Zirk is not correct. it's Zerk as in jerk. There, I was snarky, how's that.:eek:
Mister
130
Northwest
Geohorn already slapped you around quite eloquently, (assuming you didn't somehow miss his post), so I'll just leave it there. Sounds like you need some coffee to wash down that crow
Captaincj
Hugo, MN
Old thread, but epic post.
Might buy those Zerk caps as well!
Bravo, you win the internets for that day back when you wrote it.
4,269
