M8540 PTO Question
The Bob
M6800 Kubota, 1953 Ferguson T030
Sep 24, 2015
11
Fort Smith, Ar
I am looking at a M8540 with about 650 hours on it, at a good price from a local wheeler/dealer. Almost too good of a price, about $5K below a local dealer for the same model with twice the hours on it.
My question is, when the PTO is engaged below 1000 rpm, there is a noticeable noise coming from the transmission area, when the RPM's get to about 1200, it goes away. I don't think the PTO has ever been used much, (still has the black cover on the shaft). Is this type of noise normal?
Second question, when it starts up, a cloud of black smoke, goes away real quick, then when you first bump the throttle a puff of black smoke, but just a puff, Again, is this normal?
I think the tractor was used to clear brush, with a grabble FEL. Now has a bucket. Everything on the tractor is very clean. One dent in a hydraulic filter. Otherwise a very clean tractor.
Your thoughts on the PTO noise and the puff of smoke?
TripleR
Sep 16, 2011
1,911
38
SE Missouri
I can't hep you on the PTO specifically as I've never engaged mine unless it was powering something and not below about 1200. Mine does puff black smoke like you mentioned.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
Not sure on the noise but the smoke sounds normal. Mine will blow black smoke at the start, I wouldn't be concerned about that.
See if they will let you demo the tractor for a day. A rotary cutter would load it up pretty good and see if everything worked properly.
