Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 5 Days Ago   #1
PoulsonRanch
New Member
Equipment: B2301HSD w/ FEL, Box Blade, Rotary Mower, Chipper
Default Throttle/Accelerator Slipping & Not holding RPMs on B2301
I've got just under 60 hours on my B2301 and recently completed the 50 hour service. I love the machine and have a ton more work I need to use it for on my land. Here's the problem I just ran into: When I set the throttle at 3,000rpms, it immediately slips back down to 2500. It won't stay any higher than 2500 without me holding it there, which is nearly impossible while needing to simultaneously drive and operate the FEL.
Anyone know how to fix this issue? A search of the forum shows a possible fix for the issue on the BX series, but I'm thinking it's not the exact same fix. If so, please let me know.
PoulsonRanch is offline   Reply With Quote
Sponsored Links
Advertisement
Old 5 Days Ago   #2
VIP Service Tech
North Idaho Wolfman's Avatar
Equipment: L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more
Default Re: Throttle/Accelerator Slipping & Not holding RPMs on B2301
2 nuts on the bottom of the lever.
Click image for larger version
Name:	B2301 throttle linkage.JPG
__________________
Some days you're being chased by the wolves,
Some days you're running with the pack!
North Idaho Wolfman is offline   Reply With Quote
Old 5 Days Ago   #3
PoulsonRanch
New Member
Thanks North Idaho Wolfman! Very helpful. Cheers.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2020, vBulletin Solutions Inc.
