rear weights on an L235
Captjack
56
Centreville,Md
What is the most weight I can add to the rear wheels of this tractor. I have the tires filled now and it made it better but I would like to have an option of some bolt on weights. I have 12.4-24 R1'S 4 PLY. They will hold 1800lbs each. I found some plates that are 200 each used on a M series that I can get cheap.
Tractor is 2100lbs dry , I have a FEL 400-500 lbs ? , rear tires (30 gal each of h2o) 500 lbs So I am around 3100lbs now with no attachments on the rear.
Captjack
56
Centreville,Md
im trying to make a big heavy tractor out of a small one !
It pulls better with more weight - lots of power out of that little motor. I dont have hills to worry about so the stopping part is not a problem, I just want it to pull ground engaging equipment better.
