Remove auger BX5450
ChuchVT
35
Johnson
I have removed every bolt from the front of the 5450 snowblower but I can't remove the auger and gear box.
What am I missing?
200mph
Mar 3, 2017
1,228
58
PA
Did you remove the chain gear from the back?
Could be rust holding the bearing located behind chain gear.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,106
926
Williamstown Ontario Canada
I haven't taken anything off the back. What do I have to remove from the back? Just the chain gear?
You need to remove anything on the fan shaft. Look for set screws on bearings and sprockets.
The big sprocket has two set screws!
Dave
BX23S
3,689
Take pictures before you disassemble, makes it a lot easier to know where and how the parts go back together when it comes time to reassemble. I was working on a snow blower this past summer, and had difficulty getting the bearing out. Then after looking at the parts schematic and the blower, I realized that it was assembled incorrectly. Don't know if it happened at the factory, or if someone at the dealership had their hands into it, and put it together incorrectly.
