Propellor Shaft Removal
4,380
I'd say remove the cover. Then you'll see the shaft. There is a coupling at each end that is usually held in place by a roll pin, but it may be a cir-clip on some tractors. Once the pin or cir-clip is removed the coupling will slide. When both coupling (front of shaft and back of shaft) are removed the shaft will be free.
If the couplings do not want to easily slide, you can spray with a solvent and then tap gently to get them to slide on the splines they rest on.
If you can get online to find a parts diagram you can see a picture of the arrangement to help you out. Look for front axle and the propeller shaft.
rbargeron
Jul 6, 2015
1,150
219
western ma
The WSM page shows the shaft has a bolted cover and snap rings - as D2Cat describes.
If its ok to ask, what's prompting removal? Take care, Dick B
everettapples
M95X, M6800, 121-3 F3060 1760
Dec 25, 2017
Island View, NB CA
Attempting to remove propeller shaft and covering tube to replace oil pan on M95X.
have tube lose and both couple pins punched out but shaft tube will not drop enough to go by the front end differential rear bearing assembly? does it have to be removed?
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,110
112
Hardisty, Alberta
You will have to lower the front axle enough so the drive shaft can be slid out above it.
everettapples
Dec 25, 2017
Island View, NB CA
Yes thank you very much for a quick reply , that makes sense.
I had contacted my local dealer and was informed the propeller shaft and tube would come out without unhooking the axle assembly.
Today I was going to attempt to unbolt the engine oil pan and see if it could be removed by pulling it forward and rolling it over the propeller shaft tubing, but this was probably wishful thinking:)
eserv
May 27, 2009
2,110
112
Hardisty, Alberta
I haven't ever tried to get the pan off that way but I have my doubts it is possible.
5,093
Yea like eserv said: that's a one piece shaft cover and dropping the front axle is the only way to get it out, odd that kubota went that route after years of a two piece shaft cover.
And I wouldn't think it even remotely possible to be able to drop the pan enough to be able to get it out like that.
