BX23S-1
535
197
No where Special
I made a kickstand for my TS rear blade (why don`t they come with them:rolleyes:)
Simple 3/4in galv pipe, flange, mounting flange, drilled& tapped 3/8ths holes.
The "pin stay" thru holes are also 3/8ths. Still need a chain put on the pin so it don`t get lost.
I screwed a square piece of pressure treated decking board on the bottom for now just to keep it from sinking in the ground when parked outside for long periods of time. But that was after i took the picture.
I also added large flat washers to the 3pt pins to remove the side to side slop on the QA hitch.
Reactions: 16 users
Flintknapper
L2350DT
May 3, 2022
1,587
2,011
Deep East Texas
OK that's pretty darn slick. I like it.
(y)
mcmxi
4,794
NW Montana
Very nice! I need to make something similar for the JD 825 turnover plow. I like that mounting flange.
BX23S-1
535
197
No where Special
Thank you mcmxi :)
You can buy all of it right at Lowes. Everything i bought was right in the pipe/plumbing department. It was very cost effective with this mod because it was really the simplest way i could do it with limited SS funds. I`ve seen so many different ways and mods that other`s have done. Some were kinda scary looking, lol. My own idea came to my brain just on a whim when i was walking around Lowes one day. I just happened to see the mounting flange, and said, yeahhhhh, i can make that work, lol. (my gears are always turning, lol) Later this summer, i plan on pulling it all back off and paint it so that it looks a little better than it does right now.
g_man
Feb 3, 2023
108
456
NE Vermont
That is a good question !!
I did the same type thing with my LandPride blade 20 years ago. Very nice job by the way. Great for non-welders !!
gg
2,813
Now thats pretty slick,, what year is the block head in the back ground?
BX23S-1
535
197
No where Special
If anyone is interested in a parts list to my kickstand build for my rear 3pt 6` blade, here you go.
I have added a galvanized 3/4in top cap on the top (that was not in the picture)
Adding the cap will keep the pipe from falling thru the mount flange.
If i missed something, let me know, i`ll post it.
Hopefully this will help some folks out here looking for a simple kickstand idea.
Everything was bought at my local Lowes
Pipe
Bottom Flange
Mount
Top Cap
Cotterless Hitch Pin
Flange Mount Bolts (3/8 x 16 x 1-1/2)
BX23S-1
535
197
No where Special
gg
Thanks g-man!
Yes sir, thats how it all happened... my welder was down, and this was an easy idea/fix.
BX23S-1
535
197
No where Special
4,026
Did a similar thing a while back. Admit I have hooked to the blade and forgot about my stand…..:):)
Reactions: 7 users
2,813
Yes Sir the TC is it EFI or carb,,, oh and if you head some one talking about a block head it is a TC,,, you know shovel head,, pan head ,, and the TC because it looks like a block :)
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,391
2,301
Finished up the "Project Wasteland" this afternoon. 20 yards of enriched soil, 100 lbs of seed and 7 bales of straw later, I will pray for rain as well as health and happiness. I "tilled" the dirt with a box blade, then spread the topsoil and went over it again. Smoothed it all down by back dragging. Then spread seed and straw.
Didn't get a photo, but the EA grapple was perfect for hauling the hay bales. Fit em all in its mouth. I closed the jaws a bit too tight and busted the twine holding two of them together. When I let them go, straw went everywhere! 😆
Reactions: 11 users
BX23S-1
535
197
No where Special
ET, that looks fantastic! Nice Job! (y)(y)
