S-G-R
LX3310, LA535, rear remotes, third function, R14's
If you just want something to make the furrow for you seeds…No idea! This is what I made the rows with then removed the furrow shovel to clean up weeds later. View attachment 81416
This is the FIL’s attachment and older than the dirt it’s plowing. Wanting something of my own that will work with my pats and euro ball hydro top link. Just trying to pick the best implement. Either the GB70, 110 cultivator or a Fred Cain 11 shank plow are in the running. I have a set of disc coming also. I don’t mind removing something for weed clean up once rows are established.
I need the furrow to make rows, then once planted, something to clean up the weeds/grass that grows before the garden shadows it out. Just can’t make up my mind or know what is the best implement. I don’t mind having to add or remove something for clean up once the beds are laid out.If you just want something to make the furrow for you seeds…
https://heavyhitch.com/product/ripper-sub-soiler-potato-plow-middle-buster/….however for that price you could get an actual middle buster / potato plow. Either of those options would be much cheaper than an EA garden bedder. I’ve thought about a cultivator, however I have not figured out the spacing for everything just yet to plant stuff so I have not pulled the trigger on that…it’s on my list though.
That makes sense. I think you could add additional sweeps in place of the discs if you wanted, however I am not sure cultivators always have the shovels on them or is it just the tines? I don’t think it matters if it works…it’s all some form or another of tilling/cultivating. Trial and error and experimenting to find what works best. I think the beer tastes better when your done. It’s better than my normal weekly job…you can believe that.I need the furrow to make rows, then once planted, something to clean up the weeds/grass that grows before the garden shadows it out. Just can’t make up my mind or know what is the best implement. I don’t mind having to add or remove something for clean up once the beds are laid out.
GB would be adding/removing the furrow shovel.
Cultivator would be removing sweeps and adding furrow to lay off rows. Reversing for clean up.
Fred Cain would be pulling middle shank for clean up.
I think the GB is the best value, as it can lay out rows and clean up with furrow removal. And, unlike the cultivator it will cover my 73” tracks.
True. Think I’m just gonna get the GB and ask if I can swap the disc for another set of sweeps and tips.That makes sense. I think you could add additional sweeps in place of the discs if you wanted, however I am not sure cultivators always have the shovels on them or is it just the tines? I don’t think it matters if it works…it’s all some form or another of tilling/cultivating. Trial and error and experimenting to find what works best. I think the beer tastes better when your done. It’s better than my normal weekly job…you can believe that.
Pushing 7.9 on my LX2610 so far, about ready to get that first greasing out of the way how long did it take you to do the full drain, fill, and filters?Took about six weeks to hit 50 hours on the LX3310 tonight. Did the oil and filters. Lost a bit more UDT then I expected and managed to get some of it on the garage floor so a normal service overall
Less than an hour. I had everything lined up and ready to go. Gave it a greasing and checked the air filters while the oil was draining.Pushing 7.9 on my LX2610 so far, about ready to get that first greasing out of the way how long did it take you to do the full drain, fill, and filters?
That's a great point. The local dealer fills them from the drain plug but I need to check the M6060 which came from a dealer in WY. I'm not sure about their due diligence yet. Thanks for the reminder.Just a note for your guys doing 50 hour service.
The front axles on new machines are notorious for being low, and nearly dry in some instances.
Don't forget to check them if you haven't done so already......
My L6060 was down 1.5 liters. The plugs were still painted over, so the dealer never checked them.Just a note for your guys doing 50 hour service.
Our old mechanical tachs are like car odometers, except calibrated for hours at rated speed. If you run at half rated rpm, it'll only register hours at half speed.. . . I think the clock is slow because I sure used it a lot more than I think that clock says. I should probably time it to see if it actually is running hourly. . .
