Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Implements & Attachments
Implements & Attachments Find everything related to operating, servicing and maintaining that loader, mower, blade, snow blower, tiller, hitch or scraper, right here.
Reply
Thread Tools Display Modes
Old 08-06-2017   #1
origami
1st Yr. Apprentice
Equipment: '12 BX25. Previous: '95 B1700
Default Sabre Samurai hydraulic hookup & options
I'm on 10 acres in Northern Virginia (outside DC), with about six acres covered in woods, with shrubs and undergrowth and bordering/encroaching on an irregularly shaped lawn. Some of this undergrowth grows quickly, gradually reclaiming the lawn from the edges and causing a maintenance challenge that I would like to address. I suspect that I easily have several thousand feet of such "border" areas that I need to deal with.
Until last summer, I'd address the biggest problem areas with a chainsaw and a gas powered hedge trimmer to cut back the encroaching vertical wall of vegetation. That came to a screeching halt when I blew out a heart valve (surgically repaired last December), which I suspected happened last summer during one of these work sessions. I've not returned to that task since but the work needs to be done and only grows.
So, when I saw the Sabre Samurai mentioned in a post here recently, it caught my eye. It's kind of pricey ($1500+), but looks fit for this purpose. Hooking it up to the bucket and doing a drive-by assault on the brush seems ideal. Problem is, my little Bx25 doesn't have a third function hydraulic control installed. Adding one bumps the overall investment another 50 percent and would have me working on hydraulics for the first time (not impossible, but would have to familiarize myself with the system and technology basics).
So, I'm wondering: Can it be run off the hydraulic lines in the back of the tractor (backhoe connections) instead of installing a third function kit? If so, how do you regulate flow rate through it (since it seems to require a constant flow of 3.3 gpm at 200 psi to drive the integrated hydraulic motor)?
I'm willing to entertain ideas for other solutions, too.
Thanks!
Sent from my SM-T713 using Tapatalk
__________________
Tom
origami is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-07-2017   #2
scdeerslayer
3rd Yr. Apprentice
Equipment: MX5200DT
Default Re: Sabre Samurai hydraulic hookup & options
If your backhoe connection is the type where you have to break the loop to install the backhoe, and then reconnect the loop when you take the backhoe off, that's not going to work without a valve. Instead of doing that, you'd be better off getting a 3rd function or a rear remote installed. The plumbing for a 3rd function really isn't that complicated, the hardest part of the install will probably be figuring out where to get the power from.
scdeerslayer is offline   Reply With Quote
Old 08-07-2017   #3
sheepfarmer
sheepfarmer's Avatar
Equipment: L3560, John Deere Gator, Ingersoll mower, Ford 8N tractor that is a little young
This probably falls under the "other solutions" category, and it wouldn't be cheaper to implement. I use a flail mower offset to one side to beat back encroaching brush and weeds. It works well. You just drive around the edge a couple times during the summer. I have brush blades on mine and it is set higher than the lawn mower would cut. For some harder to reach areas, you can lift up the mower and back up, put it down over a bush and gradually chop it into little bits.
The question would be if you can get a flail that a BX can run. You might have to trade it in on a bigger tractor
__________________
the team...
sheepfarmer is offline   Reply With Quote
Old 08-07-2017   #4
origami
1st Yr. Apprentice
Quote:
Thanks. That's the kind of connection it has. I'm going to look up rear-remotes and learn something about them.
I did write the company. They were helpful with advice on how to use their product without a third function. Granted, they stand a better chance of making a sale if they can ease that requirement. For others (in the future) that might benefit from the reply, here's what they came back with:
"Thank you for you interest on the Samurai. You could run the Samurai from your rear hydraulic port and you would control the flow by keeping your tractor at an RPM rate which would keep the Samurai at its desired speed. Another option which most of our customers use is to disconnect the lines which control the pitch of the bucket and use these ports to power the Samurai. You would hold the pitch lever to engage the Samurai and again use the engine RPM to control you flow. Most times you don't require the pitch function of your bucket when you are trimming."
Old 08-07-2017   #5
origami
1st Yr. Apprentice
Ha! Sounds just like the advice we get in my other hobby - reef aquariums. "Go bigger." It's the WAF (wife-approval-factor) that comes into play in those cases and, likely, in this one as well.
Cheaper than heart surgery, though!
Old 08-07-2017   #6
sheepfarmer
Woodmaxx sells a 54" flail for 18 to 40 hp tractors for $1949, and their picture seems to show a BX. I don't remember what my Caroni cost. It would save fooling with the hydraulics.
__________________
the team...
Old 08-07-2017   #7
Grouse Feathers
Journeyman
Grouse Feathers's Avatar
Equipment: BX2370, FEL, Snowblower-BX5455, Homebuilt Forks, LP RB1560, LP GS1548
Quote:
The Kubota rear remote kit for BXs that I bought for my BX2370 was only $330. I don't think you will be able to beat that with an after market setup. Do not look for the kit online you will only find the parts listed for a lot more than $330. Call a Kubota salesman and get a quote for the kit. The kit is designed to fit on BX tractors and used for their dealer installed option. It is easy to install if you have some piping or hydraulic experience and only takes a couple of hours.
__________________
Larry
If you sit down too long, you won't be able to get up.
The best reason to get up is to learn something new.
Grouse Feathers is offline   Reply With Quote
Old 08-07-2017   #8
origami
1st Yr. Apprentice
Thanks, it looks like a beast. However, can it cut vertically? I'm looking at a picture of it on Woodmaxx's site and struggling to see how it can turn 90 degrees make vertical cuts. That's what I need, to make a vertical cut up the side of the growth (like trimming the edge of a hedge).
Quote:
Interesting option. Do you have pictures of the assembly that you could share? Is there a detent on the control to keep the valve open (to run the hydraulic motor on the Samurai)? I don't have any hydraulic experience, but did take some time today to review the hydraulics schematic for the BX and it made sense. I still need to make a trip out to the shed to see the real hardware to get a better sense of things by tracing it all out.
Old 08-07-2017   #9
sheepfarmer
No a flail can't be turned vertically!
__________________
the team...
Old 08-07-2017   #10
origami
1st Yr. Apprentice
That's what I figured for this. There are images in Google images that show a flail on an powered arm (and references to vertical/rotating models on Wikipedia) but they look far more complex (and heavy) than the Woodmaxx series.
Yep. Considerably different. Just had to ask, though.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2020, vBulletin Solutions Inc.
