I am looking at a Powerhorse 1159 wood splitter for use with my BX2660. I understand the limited volume of my tractor results in relatively slow performace with most splitters, but I've read that many owners of similar tractors are able to use this one with more than acceptable performance.
My question is what is the best way to connect this splitter to my tractor? I don't have rear remotes; just the an FEL and its controls. I've read about connecting to the dump/curl circuit and then using a bungee cord to hold the joystick. This seems hokey. I've also read that damage to the splitter's controls could result by using the 3ph while the joystick was engaged like this.
Would it work to connect to the FEL lift/lower circuit, and then put the control in the float postion? I could get rear remotes installed (at some cost), but I suspect that they are 1/4" lines rather than the 3/8" lines that are at the FEL, which would result in less flow. I want the highest flow, best performing way of doing this.
It is probably clear by now that I am a little confused on this. I've come to you for an expert opinion. Thank you in advance.
