Electrical Problem
B1550 in Eads
B1550
Jul 7, 2015
Eads, TN
I got my Kubota B1550 out for the first time this year. The battery was dead so we jumped it off to get the tractor started. Shortly after turning off the tractor and removing the key I noticed the rear lights were on! I turned the light knob to get the lights out. Later that day the lights were on again. The following day the tractor was used to cut grass. When finished the tractor would not turn off by turning the key. The emergency shut off had to be pulled to kill the motor. The following day the rear lights were on again. I removed the battery until I can determine what is causing these problems.
Any ideas what is going on to cause these strange electrical problems?
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
Faulty head light switch vibrating on perhaps, check fuses for stop solenoid.
Check to see if dynamo is charging.
OBKubota
2014Gr2120,Gr2728Snowblower,Gck5GrassCatcher,agri-FabSpreader
Oct 21, 2014
205
Ontario
On mine it was a 10 amp fuse
