Good morning all, since my B8200 HST has an alternator and not a generator I no longer have a tach. I purchased a digital tachometer and a proximity hall sensor.
https://www.amazon.ca/ELING-Universal-Digital-Tachometer-Backlight/dp/B0755JF9FK
https://www.amazon.ca/Yosoo-NJK-5002C-Proximity-3-Wires-Normally/dp/B01LX0J9H4
I have installed the proximity sensor that take a reading off the engine front crank pully. With all the wiring connected I turned on the ignition and the tachometer lights up with all 8’s then goes to 0 RPM and 0.0 hours. Then start the engine and the RPM stays at 0. I attempted to follow the instructions for adjusting the tachometer readings by pressing the button on the back, went through all the settings in increments of 50 from 1-300. No change, 0 RPM.
The proximity sensor was bench tested and once the engine is running the led on the back of the proximity sensor is on.
Any ideas of how to test the tachometer on the bench?
