mcmxi
4,622
NW Montana
Now do you "hover" the blade over the gravel a couple of inches? I'm just imaging you pushing the rock into a big pile at the end of the driveway.
The snow blade has shoes/skids that I've adjusted so that the blade floats about 1/2" over the gravel. I run the snow blade in "float" mode and it has +/- 5 degrees of rotation built in so it does a great job. No gravel at the bottom of the driveway.
mcmxi
4,622
NW Montana
You didn't do a very good job! I still see some white on the driveway. Those pups might have 4 legs, but they don't have 4 paw drive. They need a good grip to keep going. Get out the broom and start sweeping that white stuff away! LOL :LOL: Great looking pups and a nice tractor also...
My dogs have way more traction than me! :LOL: If I can handle it they can certainly handle it. It was 4F this morning (22F now) and the snow is light, fluffy and dry so it blows and pushes easily. It's my favorite type of snow because it provides really good traction. I slipped on ice twice last year, hitting the ground hard both times and it's no fun!
MountainMeadows
Jun 6, 2022
192
254
Poconos, PA
Is your snow blade a rigid mount to the SSQA plate? I'm curious because I've been told that the blade needs to be able to pivot and float on it's own, independent of the SSQA plate, similar to the way a plow mount is on a pickup.
The way to obtain this float is to have have pins on the SSQA plate and suspend the plow with a chain and to pivot the SSQA plate forward, creating slack in the chain when the blade contacts the ground, allowing the plow to float on it's own independent of the SSQA plate and loader arms. I've been told that if the blade is a rigid mount to the plate, even with the loader in the float mode, the additional weight doesn't allow the blade to float like it should and it's more like a dozer blade.
mcmxi
4,622
NW Montana
No. the blade has a mechanism that allows it to rotate +/- 5 degrees relative to the SSQA plate. You can see the slots and bolts that allow this in the image below. The pivoting feature can be prevented (e.g. for transportation) by installing a bolt, and that's the way it came from the dealer.
L35
Jun 13, 2010
404
233
CT
New battery today. Old one was in there since 2010. I kept it on a tender for the last few years so it would start. I could leave it unplugged overnight but not much longer, esp when cold. Working out in the yard no problems ever restarting. 12 years was a great run on that battery but it’s amazing how quick it starts now, seems like a split second. I guess over the years of the battery loosing steam you forget just how fast the starter is supposed to spin.
Anyhow while the battery was out I cleaned out the area of a nest of some sort, removed and cleaned the battery ground to chassis connection and blew out the radiator with some shop air. Finally before reinstalling the battery I fluid filmed the battery box to prevent any corrosion from moisture and battery seepage.
Magicman
Oct 8, 2019
5,058
6,438
Brookhaven, MS
knotholesawmill.com
Today I was back to sawmilling after taking a Thanksgiving break.
More sawing today. Here the customer and helper are removing loose bark from the logs.
And the lumber stack grows. Those boards in the foreground are Pine 1X8's. White Oak trailer decking is behind the helper.
radas
Mar 21, 2022
721
831
Sent the LX2610 with 26.3 hours on it back to the dealer to fix a small oil leak that developed under warranty. I'm surprised that I had an oil leak but remember reading that some of these newer machines can leak from the pan due to insufficient gasket material.
Tughill Tom
B3200
Dec 23, 2013
1,102
1,116
Turin, NY
FEL off and Snowblower on and serviced. Expecting big Lake Effects here tonight and tomorrow....Good Times!
Chanceywd
Kubota L2501DT BH77 VIRNIG URG60-CT 1950 8N
Mar 26, 2021
556
390
central ny
What kind of logs are those? Don't see anything like those ends around here in my woods.
Bill
Old_Paint
Dec 5, 2020
1,539
1,425
AL
Bill
Dead pine. Not much good for finish work (the stains), but just fine for structural wood if you get 'em before they rot. Those look like pine beetles got 'em. The inner layers have a higher concentration of resin that keeps the wood from discoloring. The outer layers, while discolored, are still completely satisfactory for structural work. Even if the outer layers begin to decompose, it's still possible to get quite a bit of lumber out of logs that size. And something I've read recently suggests that staining is a quality for flooring/paneling these days. Can't think of a better way to use dead trees.
BX23S
3,694
Firewood!
  • Dislike
BXHoosier
BX24
Jan 21, 2018
453
506
Indiana
Put on the freshly painted bucket extension I made and re-mounted my tool box with a piece of channel iron from my scrap pile. Had to move the toolbox since I added the cab. The mount will get repainted when the weather warms up.
Reactions: 9 users
mcmxi
4,622
NW Montana
More snow removal yesterday and today. Here's yesterday morning before getting started.
And here's this morning along with a view up and down the gravel driveway after using the plow.
Reactions: 8 users
enriquesonora
Kubota LX2610, 66" bucket, BB1266...
Jul 11, 2022
17
17
Vail
I have just did the same with my LX2610 this week, was going to make first oil change 50hrs, and noticed leak on the RH axle case. Checking the schematics I cannot believe the factory doesn't have real gaskets! Only paste. lost about a gallon of oil. Haven't heard back from dealer since pickup two days ago. Let me know what you experience.
Old_Paint
Dec 5, 2020
1,539
1,425
AL
Strange. I haven't had a single drop leak from my 2019 model, other than what I spilled. I have not been gentle with the tractor, either. I'm just over 200 hours.
BX23S
3,694
Different people on the assembly line put these parts together. One group cares about quality and follows proper procedures; the others see it as a job and go home without pride in their workmanship.
mcmxi
4,622
NW Montana
Is that true of Japanese companies? I've had zero issues with four Kubota tractors and a Kubota generator, all made in Japan.
radas
Mar 21, 2022
721
831
Definitely will let you know, I was shocked to see drops of oil on my garage floor after 23 hours or so. Besides stump grinding with an in-spec unit, I haven't done anything too crazy with my tractor yet. My leak involved oil accumulating on the LH side frame rail (when viewed from the back of the machine). Oil filter was clean and dry and what little of the pan I could see when crawling underneath appeared dry but I'm still assuming there's a leak from that vicinity. Oil tends to creep pretty far from the source lol
Yeah I haven't read too many reports of engine oil leaking on here or elsewhere especially with low hours. I'll report back what the culprit was as soon as the dealer calls me. They are supposed to get it in the bay tomorrow AM.
Agreed, and there is a pretty high margin of error with liquid gaskets especially if they are hand installed and/or not allowed proper time to set up and cure before oil is introduced. If the unit was out of warranty, I'd drop the pan and put some Hondabond on it and let it cure for 24-48 hours before adding any oil.
radas
Mar 21, 2022
721
831
Japanese companies typically have a higher level of QC than others, this leak would have been caught at inspection of it was present in my opinion but seemed to have developed after the fact. I've seen QC cameras that can measure sealant application and thickness (among other things) on the assembly line in automotive facilities but I'm not sure what Kubuta's investment is in that regard.
mcmxi
4,622
NW Montana
It's certainly disappointing when a new vehicle has issues. I've had such a positive experience with Kubota that it would be very difficult to consider another brand in terms of tractors or excavators. Japanese workers typically have real pride in what they do, regardless of what that is.
Running the MX today and listening to the smooth four cylinder engine purring under load is just music to my ears. Such a great tractor and a real joy to own and use! :)
