R RCJC New member Equipment Kubota 2380 BX with attachments Mar 31, 2022 3 0 1 Morris, Oklahoma Aug 6, 2022 #1 It's stuck. Why? I can't figure it out. I can't start the tractor because it seems to be stuck in the on position. Help!
R Russell King Well-known member Equipment L185F, Modern Ag Competitor 4’ shredder, Rhino tiller, rear dirt scoop Jun 17, 2012 4,652 994 113 Austin, Texas Aug 6, 2022 #2 Disconnect any implements from the tractor and then see if you can get it back to the off position
ve9aa Well-known member Equipment TG1860, BX2380 -backblade, bx2830 snowblower, fel, weight box,pallet forks,etc Apr 11, 2021 1,202 974 113 NB, Canada Aug 6, 2022 #3 If the brake is set and the transmission is in Neutral, you should be able to start the tractor even with the PTO engaged, no?
skeets Well-known member Equipment BX 2360 /B2601 Oct 2, 2009 14,137 2,787 113 SW Pa Aug 6, 2022 #4 Lift your seat,, flip it up make sure the break is set and see if it will start, it is designed to up with the seat up for things like PTO gen sets. If it starts jiggle the PTO lever and see if it turns loose,, just a thought
W woodman55 Well-known member Equipment L6060HSTC, RTV 1100 May 15, 2022 730 521 93 canada Aug 7, 2022 #5 Is it a lever or a little yellow button ?
