Mid-mount Mower pin up LX2610
Tucker88
Kubota Lx
Oct 27, 2020
9
NH
Is there a way to Pin the mid mount mower up on the lx2610 so I can use the 3 point without dropping the mower? I know there is a bracket for the mid mount arms so they don't hang once the mower is off the tractor but I don't think they work while the mower is on.
What is everyone doing for this?
60" midmount mower
armylifer
Mar 26, 2013
1,955
696
Thurston County, WA
Do you have a height adjustment knob? If you set that knob to the highest number the mower will stay at that height when you lower the 3pt.
  • Angry
Tucker88
Kubota Lx
Oct 27, 2020
9
NH
Yes. I believe I tried that and it locked the whole 3 point and mid mount out. I will look again and see if it is operator error. I have only had it for a few days.
Thanks for the reply.
armylifer
Mar 26, 2013
1,955
696
Thurston County, WA
That height adjustment knob on mine will restrict the 3pt movement downward when the knob is placed on any number other than 0, but it still allows for some 3pt downward movement depending what number I have it set on. I don't know if your model works the same as mine but it is worth a try to see what you get.
Tucker88
Kubota Lx
Oct 27, 2020
9
NH
I will give it a go. It’s probably something I’m doing wrong
SDT
multiple and various
Apr 15, 2018
3,084
924
SE, IN
Like the B2650/3350, the LX2610/3310 use terrain following MMMs.
There is no height adjust knob.
SDT
SDT
Apr 15, 2018
3,084
924
SE, IN
60" midmount mower
Yes.
Instructions are in the mower (not tractor) Operator's Manual.
SDT
armylifer
Mar 26, 2013
1,955
696
Thurston County, WA
SDT
Thank you. I learned something today.
je1279
Dec 6, 2020
723
454
Upstate NY
There is a way to pin up the deck to use the 3 point hitch. I haven't tried it on mine yet but here is a video for the very similar B2650 that I found on YouTube.
johnjk
Apr 13, 2017
1,275
857
West Mansfield, OH
I’ve used it on my B1800 and it works well keeping it from dropping down. If I’m gonna use the rear 3pt, I’m pulling the deck off. Pain but it keeps it from getting banged up and making a mess. That being said, the deck rarely comes off. Paved surfaces are at a premium here and fighting that deck on gravel sucks
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
398
120
Glendale, Rhode Island
I have used the MMM deck "lockup" clevis pins on my B2650 with a the 60 MMM, and it worked as it should, preventing the MMM from moving down when the three point is lowered. Just guessing, but I would think that you would use the same pins. Mine are a stock number 75599-51525. I had to buy them, because I had put them away for "safe keeping" , and you can guess the rest of the story.
S-G-R
LX3310, LA535, rear remotes, third function, R14's
Jun 17, 2020
903
1,609
PEI Canada
Same setup to lock the deck on a LX2610. Got the proper bolts from my dealer when the tractor was delivered.
ROBERTSONCHRIS85
KUBOTA
Sep 16, 2021
TX
I am having the Same issue mine wont pin up. a bracket on the mower is hitting the frame leaving it about 1" short to be able to pin it up.
SDT
Apr 15, 2018
3,084
924
SE, IN
Works as intended on my B3350 but did not as delivered.
Something is not right with your installation.
SDT
cthomas
LX2610 HSDC
Jan 1, 2017
863
572
La Farge Wi
On my LX2610 they did not line up as delivered. Resetup the mower deck and adjusted as needed(way off). Also drilled out the brackets and mower mounts about 1/32 of an inch, and went with a slightly smaller clevis pin for easy installation/removal. HTH's
DaveD
B1700 HST 1996, LP grading scraper & box scraper, Bush Hog SQ60 & aerator
Jun 30, 2021
25
Central Virginia
I've been pinning up the belly mower on my B1700 now for 24 years, but wear and tear on the mower brackets has caused misalignment of the pin holes several times, so I had to make some adjustments to the adjustment directions in the owner's manual to make it all line up again. Specifically, as the front link and the brackets it attaches to wear, the correct length as pointed out in the manual doesn't work any longer. So the right adjustment is to adjust this link in combination with the rear lift rods until it all lines up correctly. with the mower touching or almost touching the underside of the tractor at the pin location. When done properly, no jack is needed to get the pins in and out; they slide easily, with just a bit of grease and perhaps a gentle up and down shaking of the deck to help them along.
The pins shipped with my 1996 vintage tractor were atrociously difficult to secure, as they were clevis pins with spring R-clips securing them on the inside. I found some longer pins with spring loaded detent balls near a tapered end and a ring connected to the outer end; I attached a looped nylon cord around the ring and they easily pop in and out now.
jrsavoie
2022 LX2610, 1963 JD4010, 1975 Ford backhoe, 1996 Toro 223D, 1999 Toro Groun325D
May 3, 2011
151
Clifton, Illinois
Has anybody pinned the deck up and used the tractor much that way?
It looks to me like all the weight hanging off the rear would cause the brackets on the front to bend after a little bouncing with the deck pinned up.
When I originally purchased the deck, they said it could also be pinned in the rear, but nobody did it because it was even more of a pain than pinning the front. They recanted yesterday.
Is there a way to pin the rear, so all the weight isn't hanging off the front?
Has anybody else had issues with the orange bracket on the left side of the 3 point bending?
Ours has bent 2 or 3 times.
They replaced it the first time.
We just got it back and the first thing I noticed was the piece was bent again or still bent, depending on if they changed it again.
Does anyone know why that piece would be bending?
We have not used the machine yet. I didn't want them saying we bent the piece.
Somebody said the part was problematic but didn't elaborate.
Thanks
jrsavoie
May 3, 2011
151
Clifton, Illinois
Is there a video on installing and removing the deck?
Apparently I could use a tutorial.
