LX2610 and mid mount mower
Orange man
Kubota L2501 LA525 loader , woods prd6000 mower, Land pride RB 1672
Jul 23, 2014
162
WNY
I have a LX2610 coming with the RCK60-30bb mower deck, wondering if there is any interference between the step on tractor and the deck? One salesman said it had to be removed.
D
Deleted member 47704
Guest
You might have to put a different one on. The brochure shows a step on a tractor with a mower, but its different a different color. The manual does not say anywhere to remove step.
cthomas
LX2610 HSDC
Jan 1, 2017
863
572
La Farge Wi
Just went and looked at mine LX2610 HSDC with the 60 inch deck and it does have steps installed(one step).
S-G-R
LX3310, LA535, rear remotes, third function, R14's
Jun 17, 2020
905
1,627
PEI Canada
Mine came with a grey cab mounted step. The mower doesn't come close to touching it.
je1279
Dec 6, 2020
723
454
Upstate NY
I have the standard step on mine with no issues but I am also using the extended stops intended for the turf tires.
lostboy
lx2610
Jan 1, 2021
31
15
OK
I have a non cab lx2610 with 60" MMM with the turf tires. The step is on the tractor.
Orange man
Jul 23, 2014
162
WNY
Thanks for the replies, Looks like it should work fine.
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
If I remeber correctly, turf tires are taller and the step can stay on, R4 tires are shorter and could be a problem with the step.
Orange man
Jul 23, 2014
162
WNY
I didnt think the size of tires would make a differance, thought lifting mower up would cause the interference with the step
je1279
Dec 6, 2020
723
454
Upstate NY
I could be wrong, but I think the issue was with the width of the turf tires and not the height. The extended stops prevented the gauge wheels on the deck from contacting the rear tires when the deck was fully raised. If you have an issue with the deck contacting the steps when fully raised, the extended stops should work for you. They do make it a pain in the a$$ to pin up the deck if you need to though.
