Hi, I have a l3901 with the la525 fel that is 3 years old.
When I went to change from my forks to my bucket the left side arm on the fel dropped down 2 to 3" as soon as I released the quick connect the right side stayed where it was, So hooking up the bucket was a total pia because of alignment.
I did call the dealer today and they said something about running a bracket from one side to the other, which I don't feel is the right way of fixing it, This tractor has 40 unabused hour.
I did forget to tell them that the backhoe out rigger on the left would also drop down after a couple days if that means anything?
One other thing is the tractor did run low on hydraulic fluid as soon I got it back from the dealer installing the new backhoe on it a year ago from a loose fitting on the bottom of the backhoe assy. Hydraulics were shuttering and fixed right away.
Any input on what would cause the fel dropping?
