Anyone know what this is?
FarmGurl
Kubota M108S Dual Speed Tractor
May 1, 2025
Semans, SK
New to tractors here. I have a Kubota M108S tractor and there is a plug located next to the 3 point hitch at the back that kept popping out during use. Finally, I lost the cap the last time I was using it. Can anyone tell me what the plug is for? There is NOTHING in the manual at all. I don't know if it's a hydraulic plug or what? Do I need to be adding anything to that chamber? Any clarity on this will help. I've made a temporary plug for now until I understand more about this. Pictures to show where I am talking about and what the tractor is.
3,088
Not familiar with your model, but my guess would be that that is an access point for an adjustment.
I close up pic down the hole from straight above might clarify that.
In the mean time, I would find something to cap that hole.
Doesn't look like a place you want dirt entering.
If you can't get a new replacement cap from Kubota, maybe something like this:
Just cut it off as needed.
BTDT
Old Machinist
May 27, 2024
377
400
NE FL
Looks like an oil fill. My guess if it keeps popping out is you have a vent clogged somewhere.
Mitjam
Jan 14, 2013
348
420
Edmonton, Alberta, Canada
I’m looking at my tractor right now. your missing a rubber plug. I would be ordering one it plugs off an inspection/ service hole for the transmission.
Dustyx2
BX22, M7060, Landpride RC-2512, Woodmax SB84
Feb 19, 2021
225
67
NE Wyoming
And check you vent. It's probably blocked and pressure build up is what was pushing it out.
Mitjam
Jan 14, 2013
348
420
yes. This plug may be a vent plug too not just a normal plug
8,700
This is the plug, put some RTV sealer on it when you install it.
The vent is up front:
