bx24 loader will not hold position
harryr6574
bx24
Mar 28, 2025
I have a bx24 that I loaned to my brother in law to remove sand from their boat ramp and then to remove a bunch of small stumps, I thought. I have done this for him many times before, but was very careful not to overload and I think that is what has happened. At any rate when I got the machine back he delivered and had parkeded it for me and I did not touch for about a week, but when I did I raised the bucket and it immediately dropped about 6 inches and would hold so I wasn't too concerned. I went out the other day and now the bucket drops to the ground and a new twist the bucket will not hold with the tilt now rendering the loader as all but unsuable. Anybody got any Ideas. I have seen the posts of the valve o-rings blowing out, but I have no leaks. Let me say that I have been a mechanic nost of my life and I am now 70 years old . I plan on doing the repairs myself, or at least trying. Any help greatly appreciated. Harry
5,883
The orings in the valve have nothong to do with the boom holding position. That is done by the seals in the cylinders. I would test the cylinders for internal leajage.
RDinNHandAZ
Kubota BX1870, FEL, BX5450 Snowblower, back blade, customized snow cab
Jun 26, 2022
103
132
Lakes Region NH and Sonoran Desert AZ
Once you determine the oil level is right run the bucket all the way way up and down several times then move the dump function to it’s extreems several times too. This will remove any air that might have been introduced if the tractor was on a slope and the pump scavagened air.
WAG
harryr6574
bx24
Mar 28, 2025
WAG
Thanks for the info. Found leak at loader control valve where the four tubess attatch. Someone said that there is a service bulletin and I will get by the dealership as soon as I can.
