B7200D Tractor looking for a Rear Grade Blade
Tractor J
Kubota B7200D
Jan 27, 2025
26
I’m looking for a Rear Grade blade to use on my B7200D tractor. The manual shows Rear Blade Max cutting width (60”) and Max Weight (350 lbs). I’m looking for one that will Angle, Tilt, and offset, to cut some Ditch line for drainage. I have found a IronCraft 4405 Grade Blade. The Spec shows width (60”) and weight (323lbs).
Pro and Con? Any Thoughts? Thank You
MtnViewRanch
867
305
Lakeside Ca.
You need to find a blade that cuts 60" when angled 40*-45*.
Weight is your friend when grading, find and purchase the heaviest blade that you can.
350lbs is nothing for grading.
I don't understand Kubota listing a max of 350lbs when the 3pt hitch is rated for over 1000lbs. Even the extended lift rating is over 700lbs. Kubota tends to rate things on the lighter side.
Find a heavier blade to get. ;)
5,646
curious.
Do you really, really need 'offset' ? All the miles of ditches and swayles I've done, never needed offset, just made a 2nd pass a bit higher.
N3BP
Sep 20, 2016
486
213
Lebanon, PA
I run an older Woods RB60 on my B7200 and have been very happy with it.
Tractor J
Kubota B7200D
Jan 27, 2025
26
Thanks for your input.
Tractor J
Kubota B7200D
Jan 27, 2025
26
curious.
Thanks for the input. One of the main reason is the deepen the drainage along my gravel road and some places the road is about 12" higher then the ground and I do not want to drive on the edge of the gravel.
Tractor J
Kubota B7200D
Jan 27, 2025
26
Tractor J
Kubota B7200D
Jan 27, 2025
26
curious.
jyoutz
Jan 14, 2019
3,376
2,412
Edgewood, New Mexico
curious.
Boy I find offset the most useful function, especially when ditches are deep or the road edge drops off. It allows you to pull gravel out of the ditch or push snow into the ditch without getting too close to the ditch with your wheels. It was the primary criteria after weight when I bought my current blade.
Donystoy
Dec 10, 2013
663
300
Binbrook, Ontario
You would have to have a lot of additional weight on a b7200 to keep it going straight with a 60” rear blade just angled without been offset. Tractor is way too light. Very light grading only.
