What's this??? (SOLVED)
8,734
Fixed it for you 😂
When we get our home built, I'm gonna invest in my own modem and wifi router.
I'm planning on labeling it FBI surveillance van 😁😁😁
I'm figuring things should get interesting at the tweakers house down the street from us 😬😬😬😬😬
8,734
I saw that, but looks like something splices behind that. Wasn’t sure how/what they did on rentals, that’s why I paged ya 😁
No worries. Think stupid simple circuit. Those other two splices are probably keyed power and ground. Possibly a monitor for fuel level.
If only three wire, then definitely, power, ground, and keyed power.
If that's a quick connect where the wires tie to the zip tied box, then I would just pull that fuse out of the portable fuse holder. And disconnect the box.
5,850
google found it real fast.
Curious, I wonder why the seller didn't take it off ??
Gotta be worth a few bucks.
read the manual and remove it !
BTW , it has 1 input, 1 output, so 'they' can disable the tractor anytime.
3,682
Good Catch!
Speed25
L2501(sold) - BX25D
Apr 23, 2024
273
416
NC
And the whole time I thought the discussion was about the larger white translucent box! o_O
The gauge cluster's probably pretty obvious when viewed from a different angle. :ROFLMAO:
To be fair, at first I thought it was the top of a headlight and was confused as to what part of the tractor I was looking at.
dperky
L3800D
Mar 18, 2024
Seguin, TX
Thanks very much for your help. I do have a WSM just not sure if its exactly for this tractor which is a L3800D with HST. if you have a WSM link send it along and i can double check with the one I have.
Here are pics of the relay. The green wire from the GPS unit splices into the orange wire shown in these pics. I assume the rest of the wires into the relay are stock. Except maybe the jumpers?
dperky
L3800D
Mar 18, 2024
Seguin, TX
NO MAS! I just clipped the hot and ground wires from the splices in the main wire bundle. Then clipped the the green/orange wire going to the added relay which is spliced into the starter wire. It's coming out next. Thanks again the help guys. This forum is a great resource!
3,682
🤣 😅 🤣…. but….Finally…. your light-bulb lit up…? 🤣
Yotekiller
Sep 29, 2023
459
578
Southern Indiana
Being an IT guy, I had my home wifi named this exact name. I lived in a large neighborhood back then but nobody ever said a word lol
