Have a hand dug well about 6' in diameter laced with rock, 24' to the bottom and then 4' of muck. Water lever was down to about 18' a while back. I have an elec. pump setting at the top and pumps water up to a couple hydrants and an automatic waterer. The pump house is a chest freezer modified on one end for of elec conduit to barn panel and water exit to hyd. Other end of freezer has a hole for the suction pipe.
Well also has a hand pump. I'm replacing the leathers on the check valve and suction in the cylinder on the suction pipe. I broke the cylinder trying to remove the ends! Finding a replacement cylinder becomes a task since they are a thing of the past. After going through my "bone pile" I found two more cylinders!! One is brass. It's too nice to put into a well.
