Piranha Tooth Bar Safety Guard
retiree-urgency abandoned
B3350, Kub. 5" rotary cutter, LP 48" forks, Titan Aerial Platform, KK XB Dump
Dec 1, 2020
42
Bloomington, IN
Just got my tooth bar from BXpanded. So far do good, After reading all of the posts about various body parts snagged on Piranhas, I decided to make a safety guard as a preemptive measure. Since I tend to keep bits & pieces around, I had a short section of corrugated drain tile lying around. Slit it lengthwise and it slips snugly over the sharp edges when I'm parking it in the barn.
2,158
I find that if I place the bucket down and curl it up a bit ........... my shins remind me to never park it that way again!
2,233
Did the same thing with 2 1/2" pvc:
Mark_BX25D
Bx25D
Jul 19, 2020
1,611
1,140
Hmmm. Some good ideas. I have one, but hadn't thought of a protector like that. I tend to park it with the bucket pointing down, so the Piranha isn't a danger.
But there's probably a reason I shouldn't do that.....
OrangeKrush
Nov 15, 2020
1,047
514
Indy
I always set it flat against the concrete floor so when I or my dog walks by there's no chance of snagging a sharp edge. But that is a good safe guard!👍
DVR
Kubota MX5400, L3560LE, L3301
May 8, 2020
109
66
Columbia, SC
I do the same. My piranha toothbar works the same as when it was new and has suffered no ill effects.
Nice ideas but it's a solution to a problem that doesn't exist (for me). Can see where it would be good when someone is loading the bucket with firewood, trash or debris. However, I have two identical buckets. One without so I use it for those types of things.
Quick
B2601, LA435, BH70, LP SGC0554 Grapple, LP RB1672 Rear Blade, King Kutter 60" BB
Sep 23, 2021
140
247
St. Clair, MO.
Have the same tooth bar and it rocks. Always lay it flat on the ground when not in the seat. (-;
Mlarv
BX23S
Jan 19, 2020
218
176
Crossville TN
My tractor spends time in and out of the garage. When ever I park it I roll the bucket down a bit then lower it to the ground. This way if outside no water sits in the bucket, or if in the garage I don't walk into it.
Mark_BX25D
Bx25D
Jul 19, 2020
1,611
1,140
Exactly. Well, except for me, there's no garage!
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,383
2,293
That could also double as a driveway protector for snow removal. The guy that clears my parents driveway puts one on his track loader every winter. I thought it was genius. I think he used 2" and notched for the teeth. Never a scrape on their asphalt.
Mark_BX25D
Bx25D
Jul 19, 2020
1,611
1,140
There's a guy on YouTube who shows that, not on a bucket, just on his front mounted snowblower. Keeps it from picking up gravel.
2,364
LOL.
With my luck I would trip on the ends sticking out beyond the loader and break my neck!
OrangeKrush
Nov 15, 2020
1,047
514
Indy
LOL.
They come in adjustable lengths.. 😁
3,821
My bucket doesn't have teeth, and if it did, they would be plastic held in with
Dental Adhesive i.e. Polident :rolleyes:
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
372
175
Randolph county N.C.
IMO a solution in search of a problem. Pointy sharpy things should be on the ground to avoid injuries.
