J Jerry Coon New member Equipment F3680 Aug 5, 2022 1 0 1 Michigan Aug 5, 2022 #1 The right rear wheel on my 3680 periodically locks up while moving. Any ideas why?
mikester Well-known member Equipment M59 TLB Oct 21, 2017 3,147 1,630 113 Canada www.divergentstuff.ca Aug 6, 2022 #2 Broken brake pad? Damaged ring/pinion gear? Jack up the rear end and spin the wheels by hand to see if you can find a bad spot.
whitetiger Moderator Staff member Equipment Kubota tech..BX2370, RCK60, B7100HST, RTV900 w plow, Ford 1100 FWA Nov 20, 2011 2,582 1,102 113 Kansas City, KS Aug 7, 2022 #3 Jerry Coon said: The right rear wheel on my 3680 periodically locks up while moving. Any ideas why? Click to expand... Does the knuckle have any oil in it? You have probably broken a tooth off of one of the bevel gears or have a failed bearing. You can remove the wheel and the cover to gain access to diagnose.
