Hydraulic air purge
Stmar
B2650HSDC
May 23, 2017
932
Buffalo, Wyoming
I need to replace a hydraulic hose on my FEL. Will just operating it purge the air or do I need to do something more?
Roadworthy
L2501 HST
Aug 17, 2019
1,647
528
Benton City, WA
I've never had to purge air with a simple hose replacement, just be sure to tighten the fittings and check for leaks.
3,200
Actually, unless you filled the hose with oil as you installed it somehow, you did purge the system of air when you operated the system afterwards. It was just a non issue…
Stmar
B2650HSDC
May 23, 2017
932
Buffalo, Wyoming
Installed and no leaks and works fine. $15 seems like a good price, thought about getting a spare but tech said it was a bad hose and not common.
