In need of advice Front Diff overhaul kit?
gonzo2850
kubota L2850
Jan 26, 2022
conover
Hello i'm new to the Orange tractor world and am in need of alittle guidance. I bought a 1995 L2850 and the front pinion bearing is destroyed aswell as the nut. you can literally wiggle the shaft around like a hot dog down a hallway. There's some oil leaks by the wheels aswell so before I dig deep into just doing a complete overhaul i'd like to get an idea on some decent parts and gaskets, where I can get them for a reasonable price. Thanks
SDT
multiple and various
Apr 15, 2018
3,084
923
SE, IN
Do not expect to find a "kit."
Once you disassemble the unit and know what you need, you will need to buy the parts from Kubota, excepting, perhaps, standard bearings.
SDT
gonzo2850
kubota L2850
Jan 26, 2022
conover
SDT
ok, any tips or things I need to look out for in this disasembly process?
5,069
Do you have the WSM (aka service manual)?
Almost all the parts will have to come from kubota directly.
You can look at the parts diagrams and get part numbers here:
If you don't have a good local dealer, hit up Messick's or Coleman equipment to get the parts sent to you.
kubotafreak
Sep 20, 2018
1,022
374
Arkansas, US
Most pinions come out the back, and the diff carrier out the pass side axle tube. You will more than likely need to drop the whole axle off the frame to work on it. Drain it first, and don't forget about the p/s lines, and axle vent if it has one.
3,147
1,630
Buy parts from your Kubota dealer. Be sure to thank them for stocking parts for a 27 year old machine. If you think K parts are expensive try comparing against NH or JD.
Special_K_Side
R-520,S,ST
Aug 5, 2022
19
British Columbia, Canada
Hey! Have had a Few R520 and 520s front diffs go bad on me in the past few months. Unsure of what you are working on or the differences. Your best bet (as per other replies) is just drop it and investigate! I had two R520S front diffs blow a week apart and dropped them both and managed to build one out of two (Shafts, bearings, planetary and crown gears had too come from Japan) but bearings able to be cross referenced from Timkin/Sks. All I needed was a vice, RTV for seals and one built out of two! The rest of the other rebuild
Was a nightmare! Had to buy a 254$ American socket from the great folks at ImperialNewton for the pinion nut and have it machines to
Fit (wall thickness too great) tourqued it on with diff in place ebrake on (bucket down) simple yet MacGyverish!
