Oil out the top of the valve cover
BobH71
B7200d
Sep 12, 2021
Colorado
I have oil coming out the top of my valve cover. I assume this means I put in too much oil?? (I only took out 3 qts and put 3 back in but maybe that was still too much??. )
Did I miss anything else that could be causing this?
1986 b7200
Oo-v-oO
2000 B7500
Oct 31, 2021
67
56
Central NH
How much air do you have blowing out of that tube? Excessive blowby past the piston rings can carry oil vapor with it.
There may also be an issue with the filter / screen in the top of the valve cover that is not coalescing the vapors back into liquid to be returned to the engine.
BobH71
B7200d
Sep 12, 2021
Colorado
It's coming out slowly.. but hard to tell since the fan is right there too. And it's not too much oil but enough to get all over the engine, starter, etc.
SDT
multiple and various
Apr 15, 2018
3,311
1,101
SE, IN
1986 b7200
What does the dip stick say?
SDT
2,011
There is supposed to be a hose that runs from the valve cover down to the bottom of the engine to keep it from making such a mess on the engine.
Some people attach a small can to the hose to see how much oil output there is.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
988
1,332
Pittsburgh
There should be a slobber tube on that spigot or a hose to return to the intake tract.
