Piping a grapple from rear remotes - suggestions?
ctfjr
L3800HST
Dec 7, 2009
1,705
1,919
central ct
While I'm still a long way off from receiving my grapple I thought I'd run the hydraulics to it while I wait.
Here is my goal. The grapple will connect with breakaway couplers mounted on the round tube that goes between the loader arms. From there I would go back on the right side to the area of the fel control valve. There I can take advantage of the existing hose loop that allows for the rotational movement of the arms. At that area I will have another set of couplers jic I ever want to remove the loader.
From those couplers it goes to the back going under the right side foot well, over the hydraulic filter, over the rear axle and up to the remote connections.
Below is the path I'm proposing. I would appreciate any comments on anything I missed or a better way.
Oh, and I marked my arrows backwards :( I was thinking about it from back to front
Then from under footwell follow hoses to loader valve
then follow the bundled hose loop to get under the fel arm - its somewhere around here I need the coupler set, perhaps a bracket mounted to the 5" loader support tube?
Pop out from under the arm and go to breakaway couplers
Plate with breakaway couplers here for the grapple connection
Well that's the plan, any suggestions?
Matt Ellerbee
MX6000
Jun 27, 2019
1,667
1,875
Canton, Georgia
Your idea will work, no doubt. But I believe it will be a bit clumsy, for lack of a better word. Imagine trying to grab a log while having to curl at the same time. Right hand on remote lever and left on loader stick. Also, those will be some expensive hoses!
Why not just add a proper 3rd function kit?
ctfjr
L3800HST
Dec 7, 2009
1,705
1,919
central ct
Thanks Matt for the reply. I have heard that before about using two levers while manipulating the grapple. I have 3 rear remotes and am only using 2. So its a fairly inexpensive test to try. If lever use turns out to be a deal buster there is always plan B.
A guy I met a Tractor Supply told me he does it and it just takes some getting used to. We'll see.
BigG
Sep 14, 2018
1,949
765
West Central,FL
When I did my MF1528 a small tractor back in 2005 it cost over $200 for the hoses. At that time there was no third function option. If you do follow your plan double check the movement of your 3 point arms will not interfere with the hoses. Have some one watch on your trial runs to make sure there is no problem. Ask me why I warned you. Spread the arms wide and hold them narrow as you raise and lower them to make sure there is nothing rubbing on them.
je1279
Dec 6, 2020
723
454
Upstate NY
I'm in the process of doing the opposite. I have a 3rd function and wanted to add a rear remote for a hydraulic top link. I believe the hoses, fittings and quick connects were around $165. I ordered the hoses through Surplus Center but I only needed two 7' hoses for mine. Looks like they have 12' 3/8" hoses for around $25 if those will work for you. I also ordered a hose sleeve from Amazon that will cover both hoses end to end.
Matt Ellerbee
MX6000
Jun 27, 2019
1,667
1,875
Canton, Georgia
Summit hydraulics has a kit for L3200, L3400 and L4600. I’m sure one would work for your L3800. Yea, it’s $550, but I bet you’d be close to that with 2 12+’ hoses.
MattN03
2011 B3200, LA504 FEL w/B2366 SSQA conversion, BH76 BH, EA Wicked 55
Sep 5, 2016
222
40
KY
I was planning to use my rear remotes initially to save costs, but after estimating hose costs at around $200 and operation being clumsy since the valves are near my right elbow on a B3200, I coughed up the money for the WR Long 3rd function. Haven't installed it yet, but I think it'll be easier to use.
A coworker with a much larger New Holland says he uses the rear remotes for his grapple and it's fine. His controls are in a more convenient location so I think that could be the main thing to take into consideration.
m7060
41
london, ky
I die the same thing on my M7060. Works perfect. Cost about $220 for hoses, quick connects, protective sleeve material and zip ties. Considerably less than $1000 for 3rd function. If you are looking to run production then 3rd function is the way to go
Chad D.
234
111
Eugene
I haven’t looked at pricing, but wonder how much it would be for a simple mechanical diverted valve and shorter lines. If I didn’t already have a 3rd function kit, I’d divert the curl/dump valve to run double duty with the grapple. Keeping it all under one hand would be nice so you can still drive...
4,053
hmm, for the 'plumbing layout' use two old garden hoses as standins for the $$ hydraulic hoses. you can tyrap them in place and drive around,exercise the loader to see what happens.Even use them as templates for proper length.
as for gappling, I suspect you usually get under the log or brush, then 'clamp down', haul away., when done enough times, 'muscle memory' will do the 'sequence' for you, without thinking.
3,345
A 12v diverter valve is $120 - all you need beyond that is a push button switch on the joystick and some wire. Cheap, clean, and comes off with the loader.
