B7000 2 point hitch conversion to 3 point
AmericanPlumber
B7000
May 20, 2019
Rogers, united states
I just bought a b7000 with the tiller attachment. I would like to take it off and make it a 3 point hitch but don't know what size swing arms to get or where. This is my first tractor. I'm not sure on what type of transmission oil to use either. It has a front end loader as well that runs off the transmission oil. Thanks
4,853
You will need to find the lower arms and mount off of a B7100, B6100.
I don't think you will even have the pivot point that you need.
You need to post a picture of the rear lower section for us to tell more.
The fluid is easy, any hydraulic fluid that is UDT compliant will work perfectly.
Since it's a grey market tractor , you can look at the main pages of the forum and get the filter numbers, looks like all the filters are the same as a B7100.
KevinK66
B7000 FEL,tiller. BX25
Jul 21, 2016
MB
How did your conversion turn out?
I am in the process of converting my B7000 to a 3 pt hitch as well but I a, having trouble taking the original pivot point off. How did you get yours off? 92F14B9A-FBBC-4221-ADC4-13587B746B0F.jpeg 5C882B81-A046-48CA-A0DD-538DF3CA905F.jpeg
I’ve tried hammering, lots of penetrating oil and heat but the bloody thing will not budge!
Riccardo
kubota b7000, aratro, trinciastocchi, fresa ecc
May 29, 2021
nuovo
Come è andata a finire la tua conversione?
Sono in procinto di convertire anche il mio B7000 in un attacco a 3 punti, ma ho problemi a togliere il punto di articolazione originale. Come hai fatto a toglierti il tuo? View attachment 59779 View attachment 59780
Ho provato a martellare, un sacco di olio penetrante e calore, ma la cosa insanguinata non si smuove!
[/CITAZIONE]
ciao, sotto alla scatola del differenziale ci sono tre bulloni con chiave da 13 o 17 (non ricordo) dovresti provare a svitare questi tre e poi il gancio per il carro dovrebbe venire fuori.
fammi sapere se ci sei riuscito.
2,203
I am in the process of converting my B7000 to a 3 pt hitch as well but I a, having trouble taking the original pivot point off. How did you get yours off? View attachment 59779 View attachment 59780
On mine, that hitch has a bolt with locknut on the bottom side that must be loosened before the bar will slide out. The bolt sits in a recess in the bar to keep it centered.
KevinK66
Jul 21, 2016
MB
Thanks Lil Foot. I did remove that bolt. Turns out the pivot was seized and needed to be heated to be persuaded to leave its home for the last 40+ years 😤.
The 3 pt hitch is on my tractor. I had to fabricate the top link bracket, not the best welding job but it works. 524DFD55-2ED3-4B44-936B-F22CE49818C7.jpeg
