Oil recommendation
n4khq
M6040, M7040, L39 Backhoe, M8560, MX5800HST, MX6000
Nov 10, 2018
40
Dahlonega, GA
I have a L39 backhoe and MX5800 in need of an oil change. The manual for call for SAE 15W-40 in both tractors. I have enough Shell Rotella T4 Triple Protection Conventional 15W-40 Diesel Engine Oil for the L39 tractor and enough Shell Rotella T5 Synthetic Blend 15W-40 Diesel Engine Oil for the MX5800. Is there any reason I should not use the oil on hand? Thanks
2,825
I would use it in a heartbeat!
Why not? Both are fine oils - and I bet you will change them in the future according to a schedule.
As much as I believe in synthetic oils being "better" than conventional oils - the conventional oils today are so damn good the different between the two is hard to see when changed at typical intervals.
3,389
I would use it in a heartbeat1
Completely agree.
BigG
Sep 14, 2018
1,951
773
West Central,FL
I have a Duramax with 450,000 miles on it. Never has "burned" the Rottella 15-40 I put in it. It does use a little in the 10,000 mile oil changes.
I know it is not an orange tractor but it is a diesel.
n4khq
Nov 10, 2018
40
Dahlonega, GA
Thanks for the replies. It's nice to hear the answer you are hoping to hear.
