I have a B2782 front mount snowblower that I use on my B7800. It works great for the snow in Sandpoint, ID. Recently the chain came off and I noticed that the large sprocket on the input shaft was missing the allen screws. Given the wear in the teeth of both sprockets I decided to buy some parts and replace both sprockets and put on a new chain. Replacing the small sprocket in the steel box resulted in new bearings and a shaft because there just wasn't a pretty way to get the bearings off the shaft.
When I mounted the large sprocket onto the input shaft I found out that the input shaft end is really worn. Worn bad. The large sprocket is sloppy loose and no matter how I tighten the two allen screws it results in the large sprocket not being centered on the shaft. So the chain will be loose and when I rotate the sprocket 180 degrees the chain is tight. That won't work long term.
I purchased a new input shaft and this is where I need some guidance. The internet does not seem to have a good video or instructions for this procedure. I know that I need to unbolt the impeller and remove the bolts for the bearing flange but how does the input shaft come out of the transmission that the auger blades go into? I have searched this forum and haven't found a discussion of this process.
Does anyone have any words of advice?
Thanks for your help.
