PTO lever loud clicking & shuts itself off L3901
TiaBreezy
L3901
Mar 18, 2020
Virginia Beach va usa
Hey there, after mowing and tilling for a bit our pto started making a loud clicking noise and whenever I would lower the tiller into the ground it would shut itself off. Like the pto lever would fly back to off. I’ve always pushed the clutch before engaging the pto. We greased it all, took off the tiller, and even changed all filters and fluids but it’s still clicking and we need to get it working so we can finish mowing and tilling for spring . Any ideas?
We have the L3901
3,296
1,709
Check the PTO cable adjustment but most likely the PTO clutch or "Dog clutch is damaged and needs replaced.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
Check the PTO engagement lever and its pivots. Mine was doing that until I lubricated the shaft on which the lever moved. I rubbed a bit of molybdenum disulfide powder into it as I wanted a dry lubricant. Dry graphite powder would probably work well, too.
malsha47
Kubota L3901
Dec 21, 2021
Pleasant Mount, PA
We have the L3901
Hey TiaBreezy, did you ever figure out what was wrong with this? I have an L3901 as well and it clicks inside the PTO when engaged. The PTO engagement cable broke on mine as well, I thought that was the issue in the beginning but I fixed that and it still clicks.
