noisy clutch by release
xk120junior
Case SEX 1947 Export model
Jan 1, 2018
Germany
The clutch on my 1979 B7100 is ocasently noisy by release .also the tractor jump by release. maybe grease the clutch bearing helps ?
tractor has 240 hrs on the clock. TOO long time standing in the Garage.
5,257
1,042
I suggest you start by going to Kubotabooks.com and downloading the workshop manual which is an excellent one.
This link may or may not take you directly to the B7100 WSM
http://kubotabooks.com/AutoIndex/in...s/&AutoIndex=308e4e4679e3ba7412a20a2f2d734ac0
I don't know your particular model but with the manual you will learn a great deal more about your tractor and its clutch.
If the clutch is not engaging smoothly, the first step is making sure non of the linkages between the clutch pedal and the inside of the engine are binding.
Usually release bearings are sealed and cannot be greased.
The jerky release may improve with use. Rust on the flywheel. Try holding your foot on the brake while moving and release the clutch until it starts slipping and then let it engage. Do this several times but don't overheat the clutch disk. You are trying to create some slippage which will wear off the rust.
6,565
The grease fitting you may be seeing only applies grease to the throw out bearing HOLDER, not the throw out bearing. As mentioned the bearing is not greaseable.
By using your tractor a bit more frequently perhaps the roughness on the clutch will disappear.
8,703
Same as what they both say.
xk120junior
Jan 1, 2018
Germany
Thank you guys .I tryed everything . the noise move and come back.
sometimes the shift easy and proper sometimes the clutch do not proper release.I will now split the tractor to check the clutch.maybe the clutch was seized by the pre Owner and have some damage on the plate.keep you informed
Sammybd
Loader backhoe
Nov 29, 2017
37
Fairview,Tn USA
I had a similar problem with my l2350. I split my tractor and found my release bearing was shot. Good luck. Most models have a view window on the side of the tranny you might want to check that before attempting to split.
Sent from my SM-G955U using Tapatalk
