so I'm presently looking at upgrading to a TLB, either the L47 or the M62. I know the M62 will do it, will an L47 with the backhoe on pick up a pallet of concrete? I know what the specs say, which is not quite. basically I usually pick up a pallet of concrete in my truck from time to time for various projects and or work. rough weight is about 3400 lbs. I have 4k lb capacity forks, but will the L47 conceivably pick it up, at least enough I can drive the truck out from under it (ram 3500 dually)
this is by far the heaviest it will have to deal with, but the cost to go to a 62 is tremendous, granted capabilites are massive improvements, but that doesn't make that $ easier to handle. I've decided on this as opposed to keeping my tractor and adding an excavator and skid steer later, I just can't justify the need to use 3 different machines/maintain/store/insure etc.
L47 at pivot is 2848 per specs.
M62 at pivot is 3960 per specs.
Thanks.
Thanks.
