1st time attaching a woods mower on a Late 70s early 80s kubota Gear driven B7100.
When I attempt to engage the lever to raise mower attachment while tractor is running it will grind loud.
I know the lift works, if I shut OFF the tractor, engage the lever to lift position and restart the tractor, the mower will lift!
Is this some type of safety feature? Or should the lever engage while tractor is running without grinding?
Am I doing something wrong?
Does anybody have a picture of your 3 point attachment properly hooked up to a mower so I can see if I have mine mounted correctly?
2. Also I have a Leinbach Post Hole Digger 7300 auger (which is the bigger model) does anyone know if this will work on a B7100? I think I need the 7200 jr model.. but wondering if it is worth trying?
3. The hydraulic fluid in my tractor is a pinkish color. Is this bad?
I do not know what type of fluid was in the machine before, but I am using Napa Hydraulic Fluid which lists as "Kubota UDT" compatible on the back label.
The Napa Fluid is clear, so the pinkish color in machine has me concerned.. of course I have an important job coming up.. and just finished replacing the FEL dump cylinder rod.. so hoping I can put machine to work for about a 3-4 hour job and then do a complete fluid change this summer.
Appreciate any advice
