What is this wire?
07wingnut
258
106
Clearwater, BC, CA
Two questions actually. This is for a BX23. There is a wiring harness overtop of the motor and coming out of it is a double white wire terminating in a single terminal connector. Any ideas what it does, it isn't hot with the key on or off.
Secondly, when checking the oil level in the front axle, is the level with the dip stick screwed in, or just with the dipstick measuring without actually screwing it in?
Any replies are appreciated, I am new to this machine and there is a lot to learn.
2,731
Not sure what the wire goes to - a picture would help a lot. As for the oil in axle, book does not talk about screwing in the stick or not, however, I would check it after the dipstick was down at it's furthest point, screw it in and then read.
you have the manual?
